Re: marker & squiggle creation problem after XML validation [message #228749 is a reply to message #228729] |
Tue, 10 March 2009 19:52 |
Frank Du wrote:
> I extended XML editor. Everything worked fine before I refactored the
> project file layout. The XML validation still works fine. After the
> validation, the problem marker is created in vertical ruler (which is
> fine), but the red squiggle isn't created as expected.
> Without the red wave line, we can't bring up the quick-fix suggestions.
> It seems that WTP XML editor doesn't set IMarker.CHAR_START and
> IMarker.CHAR_END. Instead, it sets the column and row number. So my
> questions:
> How could a problem marker infer the text that should be underlined with
> squiggle?
> How to debug and recover the squiggle creation?
> Any suggestion or clue is highly appreciated! Thank you so much!
The values aren't something that the editor affects, it's instead
the particular validator that created the problem/message that is
responsible. What is the problem/message being created?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: marker & squiggle creation problem after XML validation [message #228985 is a reply to message #228817] |
Sun, 15 March 2009 00:36 |
Originally posted by: valentinbaciu.hotmail.com
Frank, to understand how the XML validator deals with squiggles have a look
at these two classes:
org.eclipse.wst.xml.core.internal.validation.eclipse.XMLMess ageInfoHelper
org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceV alidator
XMLMessageInfoHelper adds extra information about the squiggle strategy to
use and DelegatingSourceValidator
computes more precise squiggle location (offset, length).
Hope this helps, Valentin
"Frank Du" <du.qixing@gmail.com> wrote in message
news:7f0518055a0be20f4b74a0e5cbab836a$1@www.eclipse.org...
> Yes, a validator creates the markers. It's a subclass of
> AbstractNestedValidator. For instance, the problem marker is:
> message: DataSetVersion must be equal to '2.5.4'.
> lineNumber: 9
> severity: 1
> toString(): ------ERROR-----: InvalidDataSetVersion: DataSetVersion must
> be equal to '2.5.4'. (line 9, column 19)
> The error marker appears in the vertical ruler. The squiggle doesn't show
> up in the editor.
> Any way do locate the issue?
> Thank you so much,
> Frank
> Nitin Dahyabhai wrote:
>> The values aren't something that the editor affects, it's instead the
FUDForum. Page generated in 0.03551 seconds
