Home » Language IDEs » ServerTools (WTP) » Create a WTP XML Node from an XML string
Re: Create a WTP XML Node from an XML string [message #228540 is a reply to message #228524] |
Mon, 02 March 2009 15:58 |
Originally posted by: dcarver.starstandard.org
Have you tried the cloneNode() method?
I think the problem you are going to run into though is that you are
going from two different DOM implementations. So what you might have to
do is create a custom Clone Node method that takes the input of the
Xerces DOM node, and recreates a WTP DOM node, and returns the WTP DOM
node as it's result.
Unfortunately, WTP DOM is known not to be a 100% complete implementation
of DOM, so there are edge cases where it has problems. This appears to
be one.
Dave
Istvan wrote:
> Hello,
> I'm working on an XML editor based on WTP XML Editor, so I have to work
> with a WTP DOM.
> The problem:
> I have to create a Node from an XML String and insert the node to the
> WTP DOM.
> I can create document from a String but it won't be a WTP Document, so
> when I try to insert the first child of the newly created DOM to the WTP
> DOM I
> got the following exception:
> java.lang.ClassCastException: org.apache.xerces.dom.DeferredElementImpl
> cannot be cast to org.eclipse.wst.xml.core.internal.document.NodeImpl
> at
> org.eclipse.wst.xml.core.internal.document.NodeContainer.ins ertBefore(NodeContainer.java:269)
> at
> org.eclipse.wst.xml.core.internal.document.ElementImpl.inser tBefore(ElementImpl.java:693)
> at
> org.eclipse.wst.xml.core.internal.document.NodeContainer.app endChild(NodeContainer.java:129)
> Code I use to create the DOM:
> public static Document stringToDom(String xmlSource) throws
> SAXException, ParserConfigurationException, IOException {
> DocumentBuilderFactory factory = DocumentBuilderFactory.newInstance();
> DocumentBuilder builder = factory.newDocumentBuilder();
> return builder.parse(new InputSource(new StringReader(xmlSource)));
> I browsed the wst.core code but can't find any solution.
> Can anybody help me?
> Istvan
Re: Create a WTP XML Node from an XML string [message #228548 is a reply to message #228540] |
Mon, 02 March 2009 16:08 |
Ed Merks Messages: 33140 Registered: July 2009 |
David,
I suppose one could create a WTP DOM Document and use importNode on the
root element to clone, or would that result in cast exceptions as well?
> to do is create a custom Clone Node method that takes the input of the
> implementation of DOM, so there are edge cases where it has problems.
> This appears to be one.
> Dave
> Istvan wrote:
>> Hello,
>> work with a WTP DOM.
>> The problem:
>> WTP DOM.
>> so when I try to insert the first child of the newly created DOM to
>> the WTP DOM I
>> org.apache.xerces.dom.DeferredElementImpl cannot be cast to
>> at
>> at
>> at
>> Thanks,
>> Istvan
Ed Merks
Re: Create a WTP XML Node from an XML string [message #228556 is a reply to message #228548] |
Mon, 02 March 2009 16:43 |
Istvan Messages: 15 Registered: July 2009 |
Thanks for quick replies.
I checked this just now, normal cloneNode does not work, it produces the
same Exception than without using cloneNode.
Custom cloning: I thought there is a "more standard" way than doing this but
I think I will choose it, it is sure it will work.
Although, I would give a chance to the other solution.
Ed, how can I create a WTP DOM?
Can I force the stringToDom method below to create a WTP DOM?
Istvan
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:goh09i$4bl$1@build.eclipse.org...
> David,
>> be one.
>> Dave
>> Istvan wrote:
>>> Hello,
>>> with a WTP DOM.
>>> The problem:
>>> WTP DOM.
>>> DOM I
>>> at
>>> at
>>> at
>>> Thanks,
>>> Istvan
Re: Create a WTP XML Node from an XML string [message #228565 is a reply to message #228556] |
Mon, 02 March 2009 17:22 |
Istvan,
I assume there's a factory somewhere to create a Document. But then,
I'd have assumed there'd be something to create a instance from a Reader
or an InputStream...
> the same Exception than without using cloneNode.
> this but I think I will choose it, it is sure it will work.
> Istvan
>> David,
>> the root element to clone, or would that result in cast exceptions as
>> well?
>>> have to do is create a custom Clone Node method that takes the input
>>> of the Xerces DOM node, and recreates a WTP DOM node, and returns
>>> the WTP DOM node as it's result.
>>> problems. This appears to be one.
>>> Dave
>>> Istvan wrote:
>>>> Hello,
>>>> The problem:
>>>> the WTP DOM.
>>>> the WTP DOM I
>>>> at
>>>> at
>>>> at
>>>> Thanks,
>>>> Istvan
Ed Merks
Re: Create a WTP XML Node from an XML string [message #228573 is a reply to message #228565] |
Mon, 02 March 2009 18:13 |
Ed Merks wrote:
> Istvan,
There is...but it does not implement the Standard JAXP Document
builder...with that said the following code will simulate it.
public Document load(java.net.URL url) throws DOMTestLoadException {
IStructuredDocument document = null;
Document doc = null;
IStructuredModel model = null;
try {
FileInputStream file = new FileInputStream(url.getPath());
InputStream inputStream = Utilities.getMarkSupportedStream(file);
ModelHandlerForXML xmlModelHandler = new ModelHandlerForXML();
IDocumentLoader loader = xmlModelHandler.getDocumentLoader();
document =
(IStructuredDocument)loader.createNewStructuredDocument("/home/dcarver/test.xml ",
inputStream, EncodingRule.FORCE_DEFAULT);
IModelLoader xmlModelLoader = xmlModelHandler.getModelLoader();
model = xmlModelLoader.createModel(document, url.getPath(),
xmlModelHandler);
catch (IOException e) {
e.printStackTrace();
} catch (Exception e) {
String text = model.getStructuredDocument().getText();
IDOMModel docModel = (IDOMModel)model;
doc = (Document)docModel.getDocument();
return doc;
That is some sample of how to create an WTP DOM from an input file.
Dave
Re: Create a WTP XML Node from an XML string [message #228597 is a reply to message #228581] |
Tue, 03 March 2009 03:27 |
Istvan,
If you can please open a bug report against the existing wst.xml
component, and report the issue with the cloneNode method.
It should take any DOM interface and clone the node, and not be dependent.
Dave
Istvan wrote:
> In the meantime I implemented a simple cloneNode method, it works.
> I also tested the code Dave posted: I changed it to receive an
> xml-string and build a document from it. Inserting the result as a child
> of a WTP node works, but I get errors when I try to format the node
> using xmlNodeActionManager.reformat(node, true).
> Maybe I will debug this later, but for now I will use the cloneNode method.
> Thanks a lot for both of you.
> Istvan
Current Time: Wed Apr 24 17:24:33 GMT 2024
Powered by FUDForum. Page generated in 0.03638 seconds
