Re: empty server list :( [message #227556 is a reply to message #227551] |
Mon, 09 February 2009 10:56 |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Paolo,
did you add the server runtime environment in "Window" -> "Preferences" ->
"Server" -> "Runtime Environments"?
By the way: did you install a 64 bit JRE? If yes: reinstall a 32 bit java + 32
bit eclipse + 32 bit JBoss.
Best regards
Wolfgang
paolo schrieb:
> Hi there.
> I run vista64 + ganymede(64bit version, found that it's the only one
> working) + jboss AS 5 all up to date. I use jre/jdk version 6 update 12.
> I installed jboss tools and webtools. I have an online game application
> to go on with developement so I need to run the project in debug mode
> AND with broadcast option enabled (-b 0.0.0.0) but all I can do is to
> add a new server in the "server view" without any configuration option
> (doing right click almost no options are available).
> I really need to go on "run/debug configurations" and add a new server
> to launch my app with, but the server list appears completely empty and
> I can't figure how to add my jboss instance there.
> Any help is really appreciated since I'm stuck in pre-production steps.
> I don't know how I did before since I ran everything under xp32 and
> ported the conf files to run under 64. On prior installation the server
> list was already filled with no effor afaik.
> Thanks
> Paolo, Italy
FUDForum. Page generated in 0.02781 seconds
