Home » Eclipse Projects » GEF » Centered, fixed-sized diagram with correctly positioned grid and rulers
Centered, fixed-sized diagram with correctly positioned grid and rulers [message #227382] |
Mon, 04 December 2006 20:01 |
Eric Heiker Messages: 2 Registered: July 2009 |
Junior Member |
Hi, I am making a graphics editing program using GEF and I need to be
able to edit a fixed size (like 640x480), centered diagram. It needs to
be zoomable and have a grid that has its origin in the upper-left corner
of the diagram figure. Ideally it would also have rulers that are fitted
to the diagram, but its not entirely necessary.
This is a picture of what I'm trying to achieve:
http://mediacraftlabs.com/eric/gef-layout.jpg
Here are my current results:
http://mediacraftlabs.com/eric/gef-bad-layout.jpg
At the moment I am extending a ScalableRootEditPart and overriding the
createLayers() method. There I move the scaled layers into a new layer
called centerPane. A FlowLayout is applied to centerPane to try to make
it centered, but for some reason it is only vertically centered and
horizontally it is left-aligned.
LayeredPane scaledLayers = getScaledLayers();
layeredPane.remove(scaledLayers);
Layer centerPane = new Layer();
centerPane.add(scaledLayers);
FlowLayout layout = new FlowLayout(false);
layout.setMinorAlignment(FlowLayout.ALIGN_CENTER);
layout.setMajorAlignment(FlowLayout.ALIGN_CENTER);
layeredPane.addLayerAfter(centerPane, CENTER_LAYER,
getLayer(HANDLE_LAYER));
New layer structure:
Root Layered Pane
├ Guide Layer
├ Feedback Layer
├ Handle Layer
├ centerPane <=======
├ Scalable Layers (ScalableLayeredPane)
├ Scaled Feedback Layer
├ Printable Layers
├ Connection Layer
└ Primary Layer
├ DiagramFigure <========
└ Grid Layer
Then I made a new figure called DiagramFigure which serves as the
container for all of the shapes and other figures. The DiagramFigure
has an XYLayout and I set its preferred size (640,480) and its color
(yellow) in DiagramEditPart.
This makes the diagram the right size and color but the problem is that
all of the other layers, including grid, feedback, and rulers, are all
drawn starting at (0,0) of the viewport layer and not the DiagramFigure.
If you look at the 2nd image I posted you can see that the grid layer
is slightly off. Also, when moving child figures in the diagram the
feedback layer is also drawn starting at (0,0) of the viewport so the
gray "move" square is also off. Its not just a drawing issue as
snapping to the grid is also calculated from the viewport.
I assume the solution has something to do with layouts but I can't
figure it out. Any help would be appreciated.
Re: Centered, fixed-sized diagram with correctly positioned grid and rulers [message #227663 is a reply to message #227382] |
Fri, 08 December 2006 22:23 |
Originally posted by: none.unknown.com
An easy hack is to give the layer a border.
Otherwise you could add a separate figure (page) to the layer with a stack
layout or something. That page then becomes the content pane for your
editpart and would have the XYLayout.
"Eric Heiker" <eric.heiker@gmail.com> wrote in message
news:el1uqr$2h2$1@utils.eclipse.org...
> Hi, I am making a graphics editing program using GEF and I need to be able
> to edit a fixed size (like 640x480), centered diagram. It needs to be
> zoomable and have a grid that has its origin in the upper-left corner of
> the diagram figure. Ideally it would also have rulers that are fitted to
> Root Layered Pane
Re: Centered, fixed-sized diagram with correctly positioned grid and rulers [message #227820 is a reply to message #227663] |
Mon, 11 December 2006 17:33 |
Junior Member |
Hi, thanks for your response.
Which layer are you referring to?
Also, I already have a separate figure as the content pane with a
XYLayout. The problem is that the figure is not centered and the
feedback and grid layers do not have their origin at the (0,0) point on
the figure but the (0,0) point of the viewport.
>> Root Layered Pane
>> â"o Guide Layer
>> â"o Feedback Layer
>> â"o Handle Layer
>> â"o centerPane <=======
>> â"o Scalable Layers (ScalableLayeredPane)
>> â"o Scaled Feedback Layer
>> â"o Printable Layers
>> â"o Connection Layer
>> â"" Primary Layer
>> â"o DiagramFigure <========
>> â"" Grid Layer
>> container for all of the shapes and other figures. The DiagramFigure has
>> an XYLayout and I set its preferred size (640,480) and its color (yellow)
>> in DiagramEditPart.
>> If you look at the 2nd image I posted you can see that the grid layer is
>> slightly off. Also, when moving child figures in the diagram the feedback
>> layer is also drawn starting at (0,0) of the viewport so the gray "move"
>> square is also off. Its not just a drawing issue as snapping to the grid
>> I assume the solution has something to do with layouts but I can't figure
Re: Centered, fixed-sized diagram with correctly positioned grid and rulers [message #227903 is a reply to message #227820] |
Tue, 12 December 2006 19:11 |
I was referring to the layer being created in your content editpart, also
sometimes referred to as the diagram editpart. Looking at your first post
in detail, it seems you're not creating a layer in your DiagramEditPart.
If you want to go with the two figure strategy, in your DiagramEditPart you
need to first create a Figure (or layer) and give it a shaded border (the
size of empty space all around). Give that figure a stack layout and add to
it another figure that is your content pane (which is what should be
returned in DiagramEditPart's getContentPane() method). The content pane's
layout manager should be an XYLayout.
SnapToGrid has a property so you can change its origin. You don't need to
change the feedback layer's origin. Just make sure all coordinates are
being translated properly. Your post said something about moving the
feedback layer, but you don't need to do that either.
news:elk4om$kon$1@utils.eclipse.org...
> XYLayout. The problem is that the figure is not centered and the feedback
> and grid layers do not have their origin at the (0,0) point on the figure
>> stack layout or something. That page then becomes the content pane for
>> your editpart and would have the XYLayout.
>>> Root Layered Pane
Current Time: Thu Apr 25 14:06:36 GMT 2024
Powered by FUDForum. Page generated in 0.03865 seconds
