Home » Newcomers » Newcomers » How can I tell my project template type?(How can I tell my project template type?)
How can I tell my project template type? [message #1328167] Fri, 02 May 2014 10:50 Go to next message
For a newbie in Eclipse who can't quite tell some time after starting a project what project template I chose (i.e. Dynamic Web Project, Java Project etc.) when I first started the project, how do you tell?
I can't quite recognize my project icon types in the explorer pane just yet. Is there a "properties-like" view where I can get this information about a project I started a while back and so don't remember what template I started with?
Re: How can I tell my project template type? [message #1328513 is a reply to message #1328167] Fri, 02 May 2014 14:42 Go to previous messageGo to next message
I don't think there's any way in the Eclipse UI to tell, but the simplest alternative might be to open the .project file and see what natures are applied. If it's not obvious to you, post the contents of the file here and the community can probably help identify what each nature means.
[Updated on: Fri, 02 May 2014 14:43] by Moderator
Re: How can I tell my project template type? [message #1328866 is a reply to message #1328513] Fri, 02 May 2014 18:45 Go to previous messageGo to next message
Is the .project file in the projects' directory as in one per project?
EDIT: I see, its in the project directory per project. I can't tell the template by looking at the natures. Here is what I got:
<natures>
<nature>org.eclipse.jem.workbench.JavaEMFNature</nature>
<nature>org.eclipse.wst.common.modulecore.ModuleCoreNature</nature>
<nature>org.eclipse.wst.common.project.facet.core.nature</nature>
<nature>org.eclipse.jdt.core.javanature</nature>
<nature>org.eclipse.wst.jsdt.core.jsNature</nature>
</natures>
[Updated on: Fri, 02 May 2014 19:22] by Moderator
Re: How can I tell my project template type? [message #1330226 is a reply to message #1328866] Sat, 03 May 2014 10:47 Go to previous messageGo to next message
Yes. Also, the icons are decorated and you'll get used to what they look
like over time. The .project file tells more of the story though.
Re: How can I tell my project template type? [message #1334206 is a reply to message #1328866] Mon, 05 May 2014 08:56 Go to previous message
Moe B wrote on Fri, 02 May 2014 18:45
<natures>
</natures>
That looks like a Dynamic Web project, including JavaScript capability.
Previous Topic:Photran GNU make problem under Win 7
Next Topic:Sybase Unwired Workspace - Code Generation Error
Current Time: Fri Jul 18 07:43:01 EDT 2025
Powered by FUDForum. Page generated in 0.09518 seconds
