Amzi prolog install [message #227109] |
Sat, 11 August 2007 23:51 |
Originally posted by: hellhound_overblood.hotmail.com
I'm trying to install amzi prolog on eclipse Europa (just gunziped from
the .tar.gz, so it doesnt has any other plugin), however in order to do so
in the installation instructions i found that i have to use the menu
help>software updates> find and install...
but in the moment i click on it, the program stops responding
im running it on ubuntu 7.04 (feisty) with the 1.4.2 java virtual machine
from the fsf and the 1.6.0 jvm from sun microsystems
my question is: what else should i look for to find out what the problem
is?
Re: Amzi prolog install [message #227120 is a reply to message #227109] |
Sun, 12 August 2007 06:28 |
Originally posted by: ramim.kauhajoki.fi
Juan Carlos Lozano kirjoitti:
> so in the installation instructions i found that i have to use the menu
> machine from the fsf and the 1.6.0 jvm from sun microsystems
> is?
Which JVM is your Eclipse using? I think 3.3 version need Java 1.5? I
think the Eclipse starts with the 1.4.x version but if there's some
event or tool etc. which needs Java 1.5 Eclipse just won't show these at
all.
Re: Amzi prolog install [message #227687 is a reply to message #227120] |
Thu, 16 August 2007 04:59 |
I installed the version 1.6.0 from Sun, but now it shows an error message
from another of the plugins () stating that it doesnt has the jvm 1.5 even
after adding it through the preferences, under the Installed JRE's Section
thanks in advance.
>> is?
> all.
FUDForum. Page generated in 0.08407 seconds
