Home » Eclipse Projects » GEF » Class Diagram example: multiple selection
Class Diagram example: multiple selection [message #226952] Mon, 27 November 2006 11:15
Sabri Skhiri dit Gabouje is currently offline Sabri Skhiri dit GaboujeFriend
I have implemented the class diagram example from the Eclipse WIKI web
site. The delete of multiple selections seems not working. Actually if you
select several classes and if you try to delete them together, only the
first one is deleted.
I have taken a look in debug mode, and I have found that the delete
request sent to the getDeleteDependantCommand contains only one part to
delete, actually, if you select 3 classes, 3 requests will be sent, each
of them containing only one part. Is it normal ?
I don’t understand why the 2 others are not executed, have you got an idea
Thanks.
Sabri.
Previous Topic:Rotatable Connection Label
Next Topic:Is there an API for Model => Editpart
Current Time: Sun Dec 05 00:05:30 GMT 2021
Powered by FUDForum. Page generated in 0.02154 seconds
