Home » Eclipse Projects » EGit / JGit » change directly in the compare editor will directly be added to index
change directly in the compare editor will directly be added to index [message #1327066] Fri, 02 May 2014 02:23
xi wangxi.exegmail.com is currently offline xi wangxi.exegmail.comFriend
and also there is one entry in the unstaged change box, but select adding that entry into git index will just rollback the change ( which is made in the compare editor )
seems it is better add the change to git index only when we select to add but not by default.
Previous Topic:Saving .xml files on an EGit Android Project
Next Topic:Fetch Performance
Current Time: Sun Jan 26 06:48:59 GMT 2020
Powered by FUDForum. Page generated in 0.01887 seconds
