Home » Eclipse Projects » GEF » the problem I add a image in editor
the problem I add a image in editor [message #226628] Sun, 19 November 2006 22:15 Go to next message
Originally posted by: jdenght.gmail.com
HI,Everyone:
I have add a image on diagram,when i open the editor,the image of the
diagram can not display normally.(the results in attachment1.png)
when I use Marquee tool select the diagram or drag the child of diagram,the
image will display Irregularly.(the results in attachment2.png)
how can i make the image in editor display normally?
many thanks!!!
the code add the image in diagramEditpart in createFigure method as follows:
protected IFigure createFigure() {
Figure figure = new FreeformLayer()
protected void paintFigure(Graphics graphics) {
super.paintFigure(graphics);
if(getDiagram().getBackgroudImage()!=null) {
File file = new File(getDiagram().getBackgroudImage());
if (file.isFile()) {
if (BG_IMAGE != null) {
BG_IMAGE = null;
FileInputStream input = null;
try {
input = new FileInputStream(file);
BG_IMAGE = new Image(null, input);
graphics.drawImage(BG_IMAGE, 0, 0);
} catch (FileNotFoundException e) {
BG_IMAGE.dispose();
try {
input.close();
} catch (IOException e1) {
e1.printStackTrace();
e.printStackTrace();
}finally {
BG_IMAGE.dispose();
try {
input.close();
figure.repaint();
figure.setLayoutManager(new FreeformLayout());
return figure;
Re: the problem I add a image in editor [message #226664 is a reply to message #226628] Mon, 20 November 2006 15:20 Go to previous messageGo to next message
Although I couldn't look at the attached screen shots, I've tried to help
you out here by setting a background image for the logic diagram figure.
Below I'll provide a code snippet for the extended FreeFormLayer figure
(i.e. FreeFormLayerWithImageBGR figure). Essentially, this is the code
snippet you provided in your problem description with 2 differences:
1) Image is cached
2) Image is scaled to occupy the whole diagram.
Code snippet:
package org.eclipse.gef.examples.logicdesigner.figures;
import java.io.FileInputStream;
import org.eclipse.swt.graphics.Image;
import org.eclipse.ui.PlatformUI;
import org.eclipse.draw2d.FreeformLayer;
import org.eclipse.draw2d.Graphics;
import org.eclipse.draw2d.geometry.Rectangle;
public class FreeFormLayerWithImageBGR
extends FreeformLayer {
Image image;
public FreeFormLayerWithImageBGR(String path) {
super();
try {
setImage(new Image(PlatformUI.getWorkbench().getDisplay(),
new FileInputStream(path)));
} catch (Exception e) {
System.out.println(e);
setImage(null);
public Image getImage() {
return image;
public void setImage(Image image) {
this.image = image;
if (getImage() != null) {
Rectangle targetRect = getBounds().getCopy();
org.eclipse.swt.graphics.Rectangle imgBox =
getImage().getBounds();
graphics.drawImage(getImage(), 0, 0, imgBox.width,
imgBox.height,
targetRect.x, targetRect.y, targetRect.width,
targetRect.height);
To set it up for logic example:
in LogicDiagramEditPart#createFigure() instead of:
IFigure f = new FreeFormLayer()
put
IFigure = new FreeFormLayerWithImageBGR("<full path to the image file>");
(Note: don't try SVG images)
Please try this out, let me know if this helps.
Alex
Re: the problem I add a image in editor [message #226712 is a reply to message #226664] Tue, 21 November 2006 02:01 Go to previous message
Hi,alex:
Thanks very much for your code snippet,the problem has been resolved by the
way you provided!
Best wishes to you!
jdenght
"Alex Boyko" <aboyko@ca.ibm.com>
??????:123fc64be0654e219b04d96345025015$1@www.eclipse.org...
> 1) Image is cached
> Code snippet:
> Image image;
> super();
> try {
> setImage(null);
> return image;
> this.image = image;
> imgBox.height,
> targetRect.height);
> put
> Cheers,
> Alex
Previous Topic:Two palettes in the same editor
Next Topic:The proper layout - GMF version of datagrid (widget)
Current Time: Sun Jun 15 15:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.03469 seconds
