Home » Eclipse Projects » GEF » location problem
location problem [message #226541] Thu, 16 November 2006 09:27 Go to next message
Originally posted by: Sferzah.yandex.ru
i have a container element on my diagram.
when i move any elements there - it's ok
when i create elements in root diagram - ok (use the same
CreateNodeCommand)
when i put new element (from palette tools) in my container - this element
appear in container with some offset. When i look in my
CreateNodeCommand.SetLocation - location value is right, but when this
command .Execute() - location value is wrong. Where this value can changed?
Re: location problem [message #227696 is a reply to message #226541] Sun, 10 December 2006 10:21 Go to previous messageGo to next message
I encountered the same problem as you did. I used XYLayout for the container.
Does anyone have any idea? Thanks.
Re: location problem [message #227701 is a reply to message #227696] Sun, 10 December 2006 10:33 Go to previous messageGo to next message
I tried to track/change the coordinating system of the direct container and the top-most container of a graphical node, but I still cannot get out of an offset.
Any idea will be appreciated!
Re: location problem [message #227760 is a reply to message #227701] Mon, 11 December 2006 02:47 Go to previous messageGo to next message
are you use "subdiagram"?
now i look to this process behavior and what i see.. new element laying on
subdiagram with coordinates from root-diagram
(for example - if you put container to diagram in 100,0 coordinates then
ofsset children will be only horizontal, and if you put child in top-left
container's corner - then child coordinate will be ~100,0)
lets find solution
Re: location problem [message #227765 is a reply to message #227760] Mon, 11 December 2006 03:03 Go to previous messageGo to next message
so.. in XYLayoutEditPolicyImpl.getCreateCommand (and other commands if
required)
IFigure pane = ((AbstractGraphicalEditPart)getHost()).getContentPane();
Point p = request.getLocation();
pane.translateToRelative(p);
and command.setLocation(p);
it's work to me
Re: location problem [message #227793 is a reply to message #227765] Mon, 11 December 2006 05:41 Go to previous message
Thanks Alexey,
I've just found the solution by myself by adding the following two lines to the execute() method:
child.setX(request.getLocation().x - parent.getX());
child.setY(request.getLocation().y - parent.getY());
It works.
But I find that your solution is better, so I'll use it. Thanks again.
Bests,
Previous Topic:draw2d "scrolling monitor" question
Next Topic:drawing temporary figure for selection
Current Time: Mon Jun 16 09:42:37 EDT 2025
Powered by FUDForum. Page generated in 0.20795 seconds
