Home » Language IDEs » ServerTools (WTP) » XML Editor - "Reload dependencies" only from design-mode?
XML Editor - "Reload dependencies" only from design-mode? [message #226505] Tue, 13 January 2009 10:54 Go to next message
jzaruba  is currently offline jzaruba Friend
Hello
Why are we able to reload the schemas linked into XML only from
design-mode? (Design -> Reload Dependencies)
I haven't been able to find the menu-option in the source-mode. (There are
two "Source" menus in this mode. :)
Also I can't add a shortcut for this action.
I'm used to editing in source-mode because of control over
source-formatting, and being forced to switch to design-mode because of
the reload is quite annoying and it just doesn't make sense to me. :(
Best regards
J. Záruba
Re: XML Editor - "Reload dependencies" only from design-mode? [message #226532 is a reply to message #226505] Tue, 13 January 2009 15:53 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
You can reload dependencies when the source tab is activated, by
clicking the icon on the tool bar that has the little circular arrows on
it. When you hover over it, it says Reload Dependencies.
I'm checking on assigning a keyboard shortcut, as you are correct the
command doesn't appear in the keys preference page.
Dave
jzaruba wrote:
> Hello
> are two "Source" menus in this mode. :)
> Best regards
> J. Záruba
Re: XML Editor - "Reload dependencies" only from design-mode? [message #226539 is a reply to message #226505] Tue, 13 January 2009 16:00 Go to previous messageGo to next message
Gabriel Indik is currently offline Gabriel IndikFriend
Note that there are two items in the toolbar that are available in both
design and source view modes. These items are: "Turn Grammar Constraints
On/Off" and "Reload Dependencies" (by default they are located next to the
search button, on the right). These can be accessed at any time.
Re: XML Editor - "Reload dependencies" only from design-mode? [message #226565 is a reply to message #226532] Tue, 13 January 2009 17:39 Go to previous message
To set a Key for the Reload Dependencies, go into your Preferences->Keys
and hit the Filter button. Unselect filter uncatogrized entries.
This will allow the Reload Dependiences and several other items to
appear, and you can now add your Short Cut key assignment.
Hope that helps.
Dave
> Dave
> jzaruba wrote:
>> Hello
>> of the reload is quite annoying and it just doesn't make sense to me. :(
>> Best regards
>> J. Záruba
Previous Topic:How can i validate a WST WSDL model programitically
Next Topic:double return integer
Current Time: Tue Apr 13 11:42:00 GMT 2021
Powered by FUDForum. Page generated in 0.02328 seconds
