Re: XML Editor - "Reload dependencies" only from design-mode? [message #226532 is a reply to message #226505] |
Tue, 13 January 2009 15:53 |
Originally posted by: dcarver.starstandard.org
You can reload dependencies when the source tab is activated, by
clicking the icon on the tool bar that has the little circular arrows on
it. When you hover over it, it says Reload Dependencies.
I'm checking on assigning a keyboard shortcut, as you are correct the
command doesn't appear in the keys preference page.
Dave
jzaruba wrote:
> Hello
> Why are we able to reload the schemas linked into XML only from
> design-mode? (Design -> Reload Dependencies)
> I haven't been able to find the menu-option in the source-mode. (There
> are two "Source" menus in this mode. :)
> Also I can't add a shortcut for this action.
> I'm used to editing in source-mode because of control over
> source-formatting, and being forced to switch to design-mode because of
> the reload is quite annoying and it just doesn't make sense to me. :(
> Best regards
> J. Záruba
Re: XML Editor - "Reload dependencies" only from design-mode? [message #226565 is a reply to message #226532] |
Tue, 13 January 2009 17:39 |
To set a Key for the Reload Dependencies, go into your Preferences->Keys
and hit the Filter button. Unselect filter uncatogrized entries.
This will allow the Reload Dependiences and several other items to
appear, and you can now add your Short Cut key assignment.
Hope that helps.
Dave
> Dave
> jzaruba wrote:
>> Hello
>> of the reload is quite annoying and it just doesn't make sense to me. :(
>> Best regards
>> J. Záruba
FUDForum. Page generated in 0.03504 seconds
