Home » Language IDEs » ServerTools (WTP) » Format javascript source code before save
Format javascript source code before save [message #226221] Thu, 08 January 2009 19:41 Go to next message
zubin Missing name is currently offline zubin Missing nameFriend
Member
How can I format javascript code automatic when I saving the file.
I go to preferences page ->JavaScript->Editor->save Actions, and checked
the "perform the selected actions on save" and "format source code"
checkboxes.
Ctrl+shift+f shortcut key for code formatting works, but saving the file,
the javascript code never formatted. Is this a bug of JSDT? or did I miss
something?
I am using JSDT and eclipse 3.4
Re: Format javascript source code before save [message #226230 is a reply to message #226221] Thu, 08 January 2009 19:56 Go to previous messageGo to next message
Member
I meant if I messed the codes out and then save them. The code won't be
reformatted, those codes will be left the way it is. But If I do
ctrl+shift+f to do code format, the source code will be reformatted.
Re: Format javascript source code before save [message #226237 is a reply to message #226230] Thu, 08 January 2009 20:16 Go to previous messageGo to next message
Rubin, you need to set your save actions if you want it to format when
saving. To do this, got your preferences.
Windows->Preferences->JavaScript->Editor->Save Actions
Select the Perform selected action on Save, and then select Format.
That should get you going.
Dave
Re: Format javascript source code before save [message #226243 is a reply to message #226237] Thu, 08 January 2009 20:42 Go to previous messageGo to next message
Member
Dave
Thanks for quick reply on this. I have marked both Perform selected action
on Save and format on my machine. But they are still doesn't work.
I am using eclipse 3.4 and JSDT 1.0
If it is working on your pc. Would you tell me which version of eclipse
that you are using?
Zubin
Re: Format javascript source code before save [message #226262 is a reply to message #226243] Thu, 08 January 2009 21:35 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
zubin wrote:
> Dave
> action on Save and format on my machine. But they are still doesn't work.
> that you are using?
It very much sounds like a bug. Please report it at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20So urce%20Editing&component=wst.jsdt
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Format javascript source code before save [message #226268 is a reply to message #226262] Thu, 08 January 2009 22:43 Go to previous message
Member
Filed a bug.
here is the link: https://bugs.eclipse.org/bugs/show_bug.cgi?id=260463
Previous Topic:JPA, using it, and XML mappings.
Next Topic:Adding an item to Design View's context menu via extension point?
Current Time: Thu Jan 23 00:31:24 GMT 2020
Powered by FUDForum. Page generated in 0.02171 seconds
