Re: WYSIWYG editor for html [message #225848 is a reply to message #225840] |
Sat, 03 January 2009 00:02 |
Originally posted by: dcarver.starstandard.org
Antonio DE curtis wrote:
> Hi guys,
> i have this problem, i will create a small rcp application , i search a
> plug-in for eclipse because i want insert in my RCP a WYSIWYG editor for
> html, because i am a student, i can use only
> opensource project.
> for example I see richhtml4eclipse
> (http://www.richclient2.eu/richhtml4eclipse/) , but
> i see that this project don't have a real support, do you know another
> plug-in? can you help me?
Well there are a couple of eclipse options in WTP. In Ganymede you can
install the Web Page Designer which will give you what you are looking for.
Also, if you are looking more for an authoring of documents type
application there is the Visual Editor for XML project at Eclipse. It's
under the Eclipse Incubator.
An older version of VEX can still be found at the original sourceforge
page, the newer version is still under going some development, and I
haven't had time to setup a wiki page describing it yet.
http://vex.sourceforge.net/
Dave
Re: WYSIWYG editor for html [message #225862 is a reply to message #225848] |
Sun, 04 January 2009 10:21 |
Antonio Messages: 39 Registered: July 2009 |
Member |
"David Carver" <dcarver@starstandard.org> ha scritto nel messaggio
news:495EAB27.6080509@starstandard.org...
>> Hi guys,
>> opensource project.
> for.
> Dave
Thanks Dave, the VEX is very interesting, i think use this plug in.
FUDForum. Page generated in 0.02711 seconds
