Re: How can I create a new Process type? [message #1355699 is a reply to message #1352329] |
Wed, 14 May 2014 21:15 |
Hi Marcelo,
Sorry for not responding sooner, but I'm in the middle of some major rework of the editor which won't be available until sometime in the middle of June.
Also, I'm not quite sure I understand what you're trying to do by introducing your own Process object. What I think you are saying is that whenever the editor creates a new Process element, you want it to be one of your "MyProcess" objects (which may or may not subclass the BPMN2 model's Process type). If this is the case, I'm not sure this is going to be possible. What is possible is to extend the BPMN2 Process type and add your own attributes and elements.
It would help if you could provide more details about what you're trying to do.
Bob
Re: How can I create a new Process type? [message #1357357 is a reply to message #1355885] |
Thu, 15 May 2014 13:35 |
Renan Debortoli Landim Messages: 3 Registered: May 2014 |
Hi Robert,
I'll try to explain with more details what my friend is trying to say.
First vrBPMN is model proposed by Schnieders & Puhlmann based on the BPMN 2.0 notation, and it's purpose is to add variability points in a process model by adding VarPoints (points on the process where the variability occurs, generally Tasks), Variants (which is the possible solutions for a VarPoint) and Stereotypes (determine which kind of variation is being applied, like Inheritance, Extension, etc. by the VarPoint and the Variant).
Now, our problem is, we already created a new element base on your ScreenCast, the problem Marcelo is talking about is how to "link" this new element to a new vrBPMN diagram (based on your BPMN2 plugin diagram) and how can we extend a Process Diagram so we can created a vrBPMN diagram and link this new elements to it.
By the way, couldn't help but to notice you said major rework on the editor, will it impact in this work we are doing right now? Do you sugest we wait for the rework to be done?
Hope it explained our troubles.
Best Regards
Re: How can I create a new Process type? [message #1358024 is a reply to message #1357357] |
Thu, 15 May 2014 20:08 |
I found the "Variability Mechanisms in E-Business Process Families" thesis by Schnieders and Puhlmann. I'll have a look at this to see what it is you're trying to do...
In the meantime, I'd recommend waiting until I'm done with the rework since it addresses a lot of the model extensibility issues.
Bob
Re: How can I create a new Process type? [message #1367297 is a reply to message #1364524] |
Mon, 19 May 2014 18:26 |
Hi Robert,
That is indeed the thesis I have as a base for this extension alongside with some Technical Reports from the PESOA Project, which is from Schnieders and Puhlmann, et al.
Thanks in advance for you reply, but I fear I don't have the time to wait for the rework to be done as I expected, the thing is, there is a way to extend the actual process diagram to create another type o diagram or I'll have to code some way out?
Thank you again Robert.
Best regards.
[Updated on: Mon, 19 May 2014 20:05] Report message to a moderator
FUDForum. Page generated in 0.03214 seconds
