Home » Modeling » TMF (Xtext) » DSL-Editor not found in runtime-workbench
DSL-Editor not found in runtime-workbench [message #1323763] Wed, 30 April 2014 12:29 Go to next message
Alexander R is currently offline Alexander RFriend
I have a totaly strange problem. I generated my xtext artifacts without any problems. But whem I'm running a runtime workbench and try to create or edit some of my .mydsl files, the editor couldn't be found.
I found a similar thread here: https://groups.google.com/forum/#!topic/xtend-lang/BCj17DB3pyY
But I can't find any solution for my problem. Maybe someone could help!
Alex
Re: DSL-Editor not found in runtime-workbench [message #1323822 is a reply to message #1323763] Wed, 30 April 2014 13:07 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hi,
are there any errors in the error log view? how is the status of the plugins in the host osgi console? are there any warning in the build.properties files?
hard to diagnose without any hints.
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: DSL-Editor not found in runtime-workbench [message #1323837 is a reply to message #1323822] Wed, 30 April 2014 13:17 Go to previous messageGo to next message
I've imported everything in a new workspace and startet also a new runtime workspace. The Errorlog shows me following:
[b]Cannot create extension[/b]
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:273)
	at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:318)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:266)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:61)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:304)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:61)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:676)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1042)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
And also this Error:
[b]Unable to create part[/b]
Both errors come frome the : org.eclipse.ui - plugin
Do you have any ideas where it might come from?
~Alex
Re: DSL-Editor not found in runtime-workbench [message #1323853 is a reply to message #1323837] Wed, 30 April 2014 13:26 Go to previous messageGo to next message
Hi again,
in the developer workbench are also two more exceptions:
org.eclipse.core.runtime.CoreException: Cannot create extension
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:296)
	... 123 more
!SUBENTRY 1 org.eclipse.ui 4 4 2014-04-30 15:10:02.603
!MESSAGE Cannot create extension
!STACK 0
Thanks a lot for your help!
~Alex
Re: DSL-Editor not found in runtime-workbench [message #1323876 is a reply to message #1323853] Wed, 30 April 2014 13:43 Go to previous messageGo to next message
these errors say nothing to me - is there somewhere a reasonable cause? it does not seem to be xtext releated.
are you sure you have all deps in the runtime comfig?
Re: DSL-Editor not found in runtime-workbench [message #1323903 is a reply to message #1323876] Wed, 30 April 2014 13:58 Go to previous messageGo to next message
the config is ok. The only thing I've done before, was importing the Types.ecore metamodel from the org.eclipse.uml2.types - plugin to my grammar. For this metamodel I registered the package and genmodel in the workflow-file... After a successfull generation of the xtext artefacts the editor didn't work...
I don't know really..
Re: DSL-Editor not found in runtime-workbench [message #1323911 is a reply to message #1323903] Wed, 30 April 2014 14:04 Go to previous messageGo to next message
sorry without any clue i cannot help. are you sure there is no root cause in the error log
Re: DSL-Editor not found in runtime-workbench [message #1336120 is a reply to message #1323911] Tue, 06 May 2014 08:37 Go to previous messageGo to next message
Hello Christian,
here is a screenshot of the errorlog. Maybe it will help.
https://dl.dropboxusercontent.com/u/18688378/xtext/problems/noDslEditor_.PNG
Thanks for your help,
Alex
Re: DSL-Editor not found in runtime-workbench [message #1336197 is a reply to message #1336120] Tue, 06 May 2014 09:23 Go to previous messageGo to next message
looks like your feature is broken. any warnings on build.properties files?
Re: DSL-Editor not found in runtime-workbench [message #1336239 is a reply to message #1336197] Tue, 06 May 2014 09:45 Go to previous message
I found the problem!
I had imported the org.eclipse.uml2.types.source_1.1.0 as an required plugin in my model-projekt. After removing it, all the "missing required bundle" - problems are gone.
Thanks for your support!
Previous Topic:SystemC to Promela transformer
Next Topic:Xtext plugin and context menu handler issue
Current Time: Sun Apr 18 23:40:17 GMT 2021
Powered by FUDForum. Page generated in 0.03034 seconds
