Home » Language IDEs » ServerTools (WTP) » WTP install missing dependency
WTP install missing dependency [message #225609] Tue, 23 December 2008 14:41 Go to next message
Mahesh is currently offline MaheshFriend
I'm trying to install plugin WTP (3.0.3) and there seems to be a
dependency which I need to install but can find it. Please point me in
the right the direction.
The dependency is
requires feature "org.eclipse.platform (3.4.0)", or compatible.
How do I solve this?
I'm on eclipse 3.2.
Thanks in advance.
Re: WTP install missing dependency [message #225661 is a reply to message #225609] Tue, 23 December 2008 18:54 Go to previous messageGo to next message
Lawrence Mandel is currently offline Lawrence MandelFriend
WTP 3.0.3 requires Eclipse 3.4 or above [1]. You'll need to upgrade your
Eclipse to use WTP 3.0.3.
If you'd like to stay on Eclipse 3.2 you can use an older version of WTP,
WTP 1.5 [2].
[1]
http://download.eclipse.org/webtools/downloads/drops/R3.0/R- 3.0.3-20081113203138/
[2]
http://archive.eclipse.org/webtools/downloads/drops/R1.5/R-1 .5.5-200708291442/
Lawrence
>Hi
>The dependency is
>I'm on eclipse 3.2.
>Thanks in advance.
Re: WTP install missing dependency [message #225691 is a reply to message #225661] Wed, 24 December 2008 09:43 Go to previous message
Thanks Lawrence - I need to also run the ZK plugin which required 3.4 so
will upgrade.
Ta
> WTP 1.5 [2].
> [1]
> [2]
> Lawrence
Previous Topic:Validation Framework
Next Topic:WTP 3.1 prepares corrupted war for publishing in latest M4
Current Time: Wed Oct 21 17:20:05 GMT 2020
Powered by FUDForum. Page generated in 0.01796 seconds
