Home » Language IDEs » ServerTools (WTP) » Can't get the XML editor to work
Can't get the XML editor to work [message #225370] Wed, 17 December 2008 23:58 Go to next message
Arne Skjærholt is currently offline Arne SkjærholtFriend
I've unpacked a fresh a pretty recent J2EE package of Eclipse Ganymede
(The about dialog says version 3.4.1 id M20080911-1700), and I've
installed the WTP from the update site. The main reason I installed the
WTP was to get the lovely XML editor, which I can't get to work
unfortunately. I've tried installing various other plugins and so on,
without any success.
Whenever I open an XML file all I get is the default Eclipse structured
file editor (which is kind of weird, I have to admit), but when I look
through the various preferences it looks like the XML editor installed
seeing how I can select all kinds of preferences for syntax highlighting
and so on, I just can't seem to get the actual editor to work (or maybe I
just haven't found the right place to go to in order to open it?).
Can anyone help me with this?
Arne
:wq
Re: Can't get the XML editor to work [message #225378 is a reply to message #225370] Thu, 18 December 2008 00:29 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Make sure that you have a Java 1.5 or 1.6 jre installed.
Dave
Arne Skjærholt wrote:
> I just haven't found the right place to go to in order to open it?).
> Arne
> :wq
Re: Can't get the XML editor to work [message #225386 is a reply to message #225370] Thu, 18 December 2008 00:30 Go to previous messageGo to next message
Also, what OS are you running this on?
Dave
> Arne
> :wq
Re: Can't get the XML editor to work [message #225393 is a reply to message #225378] Thu, 18 December 2008 05:23 Go to previous messageGo to next message
Yeah, I should've remembered to add that. I've got JRE 1.6.0_07, running
on Windows XP.
Arne
:wq
Re: Can't get the XML editor to work [message #225401 is a reply to message #225370] Thu, 18 December 2008 09:12 Go to previous messageGo to next message
Owen Rees is currently offline Owen ReesFriend
Member
arnsholt@gmail.com (Arne Skjærholt) writes:
> structured file editor (which is kind of weird, I have to admit), but
> when I look through the various preferences it looks like the XML
> editor installed seeing how I can select all kinds of preferences for
> syntax highlighting and so on, I just can't seem to get the actual
> editor to work (or maybe I just haven't found the right place to go to
Are you looking for the tabs at the bottom of the edit window?
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: Can't get the XML editor to work [message #225417 is a reply to message #225370] Thu, 18 December 2008 17:09 Go to previous messageGo to next message
Mark Hutchinson is currently offline Mark HutchinsonFriend
Member
If you right click on an xml file, can you see "Open With" then "XML
editor"?
> Arne
> :wq
Re: Can't get the XML editor to work [message #225463 is a reply to message #225401] Thu, 18 December 2008 22:52 Go to previous message
That's the bunny. I cannot believe I didn't see that. Thank you so much
for realising that it was a real PEBKAC-type problem.
Now, I'm just gonna sit in a corner and be ashamed of myself for a bit.
Thanks again!
Arne
:wq
Previous Topic:The Outline view and XML Editor are not kept in sync
Next Topic:no XML object
Current Time: Sun May 16 17:31:43 GMT 2021
Powered by FUDForum. Page generated in 0.01645 seconds
