Home » Modeling » TMF (Xtext) » how to enforce resource generation when having deep cross-reference over multiple resources
how to enforce resource generation when having deep cross-reference over multiple resources [message #1321797] Tue, 29 April 2014 14:04 Go to next message
Guy H is currently offline Guy HFriend
I just started using Xtext a couple of months ago. I have the following grammar:
grammar org.example.entities.Entities with org.eclipse.xtext.common.Terminals
generate entities "http: //www.example.org/entities/Entities"
import "http: //www.eclipse.org/emf/2002/Ecore" as ecore
import "http: //www. eclipse.org/xtext/common/JavaVMTypes"
Model: entities += Entity | Composite;
Entity:
  'entity' name = ID ('extends' superType=[Entity])? '{'
    attributes += Attribute*
    strings += StringAttr*
StringAttr: 'string' name=ID;
Attribute:
  type=[Entity] array?=('[]')? name=ID ';';
EntityField:
    'field' field=[Entity];
Lets say I have 3 files:
file first.entities:
entity entity1 {
  string s
file second.entities:
entity entity2 extends entity1 {
  string s2
file third.entities:
entity entity3 extends entity2 {
  string s3
when I modify entity1, for example add string myString to it, then the doGenerate(..) method is invoked twice - for first.entities and for second.entities due to the cross reference between entity2 and entity1, but third.entity resouce is not passed to doGenerate(..).
how can I trigger a change event across the entire dependency tree?
Re: how to enforce resource generation when having deep cross-reference over multiple resources [message #1321914 is a reply to message #1321797] Tue, 29 April 2014 15:31 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
hi what about the following hook org.eclipse.xtext.resource.IResourceDescription.Manager.isAffected(Collection<Delta>, IResourceDescription, IResourceDescriptions)
(i fear you have to dive yourself to see what todo)
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Previous Topic:Read my DSL model "as a whole"
Next Topic:Accessing language preferences
Current Time: Tue Aug 04 05:55:09 GMT 2020
Powered by FUDForum. Page generated in 0.05657 seconds
