Home » Archived » Maven Integration (M2E) » [tycho-dev-1819] error while building jar
Re: [tycho-dev-1819] error while building jar [message #21971 is a reply to message #21925] |
Thu, 12 February 2009 14:52 |
Originally posted by: igor.ifedorenko.com
This exception does not tell much, unfortunately.
Assuming you checked available disk space and file permissions already,
can you check if C:\workspaces\tycho\MyPlugin\target gets created during
the build? package-plugin mojo does not check/create project output
folder, so it would fail if previously executed mojos did not create the
folder.
Also check bin.includes and bin.excludes in build.properties.
If both target folder and build.properties are okay, then I would like
to see full debug log with stack traces (i.e. -X -e) or a sample project
that demonstrates the problem.
Igor
Patrick Roumanoff wrote:
> Tycho is fantastic: I have been looking for years for a way of
> integrating my eclipse RCP build with maven wihtout success, and this
> one looks like a winner.
> I have managed to successfully build and install a couple of my plugins,
> but then I hit this blocker and don't know where to look...
> Everything goes fine until the packaginf phase:
> [INFO] [osgi-packaging:package-plugin]
> [INFO] Building jar:
> C:\workspaces\tycho\MyPlugin\target\MyPlugin-1.0.0-SNAPSHOT. jar
> [ERROR]
> Internal error in the plugin manager executing goal
> 'org.codehaus.tycho:maven-osgi-packaging-plugin:0.3.0-DEV-18 19:package-plugin':
> Mojo execution failed.
> with stackTrace turned on (-e) I have the following:
> Error stacktrace:
> org.apache.maven.lifecycle.LifecycleExecutionException: Internal error
> at
> org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHandleFailures(DefaultLifecycleExecutor.java:528)
> at
> org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegmentForProject(DefaultLifecycleExecutor.java:288)
> at
> org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeT askSegments(DefaultLifecycleExecutor.java:214)
> at
> org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute( DefaultLifecycleExecutor.java:172)
> at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:218)
> at
> org.apache.maven.embedder.MavenEmbedder.execute(MavenEmbedde r.java:899)
> at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:176)
> at org.apache.maven.cli.MavenCli.main(MavenCli.java:63)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.codehaus.plexus.classworlds.launcher.Launcher.launchEnha nced(Launcher.java:289)
> at
> org.codehaus.plexus.classworlds.launcher.Launcher.launch(Lau ncher.java:229)
> at
> org.codehaus.plexus.classworlds.launcher.Launcher.mainWithEx itCode(Launcher.java:408)
> at
> org.codehaus.plexus.classworlds.launcher.Launcher.main(Launc her.java:351)
> at org.codehaus.classworlds.Launcher.main(Launcher.java:31)
> Caused by: org.apache.maven.plugin.PluginExecutionException: Mojo
> execution failed.
> at
> org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPluginManager.java:645)
> at
> org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeG oalAndHandleFailures(DefaultLifecycleExecutor.java:521)
> ... 16 more
> Caused by: org.apache.maven.plugin.MojoExecutionException: Error
> assembling JAR
> at
> org.codehaus.tycho.eclipsepackaging.PackagePluginMojo.create PluginJar(PackagePluginMojo.java:151)
> at
> org.codehaus.tycho.eclipsepackaging.PackagePluginMojo.execut e(PackagePluginMojo.java:93)
> at
> org.apache.maven.plugin.DefaultPluginManager.executeMojo(Def aultPluginManager.java:623)
> ... 17 more
> Caused by: org.codehaus.plexus.archiver.ArchiverException: Problem
> creating jar: C:\workspaces\tycho\MyPlugin\target\MyPlugin.jar (The
> filename, directory name, or volume label syntax is incorrect) (and the
> archive is probably corrupt but I could not delete it)
> at
> org.codehaus.plexus.archiver.AbstractArchiver.createArchive( AbstractArchiver.java:690)
> at
> org.apache.maven.archiver.MavenArchiver.createArchive(MavenA rchiver.java:332)
> at
> org.codehaus.tycho.eclipsepackaging.PackagePluginMojo.create PluginJar(PackagePluginMojo.java:147)
> ... 19 more
> Caused by: java.io.FileNotFoundException:
> C:\workspaces\tycho\MyPlugin\target\MyPlugin-1.0.0-SNAPSHOT. jar (The
> at java.io.FileOutputStream.open(Native Method)
> at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
> at java.io.FileOutputStream.<init>(FileOutputStream.java:131)
> at
> org.codehaus.plexus.archiver.zip.ZipOutputStream.<init>(ZipOutputStream.java:263)
> at
> org.codehaus.plexus.archiver.zip.AbstractZipArchiver.createA rchiveMain(AbstractZipArchiver.java:322)
> at
> org.codehaus.plexus.archiver.zip.AbstractZipArchiver.execute (AbstractZipArchiver.java:242)
> at
> org.codehaus.plexus.archiver.AbstractArchiver.createArchive( AbstractArchiver.java:673)
> ... 21 more
> [INFO]
> [INFO] BUILD FAILED
> [INFO]
> [INFO] Total time: 8 seconds
> [INFO] Finished at: Thu Feb 12 23:51:46 EST 2009
> [INFO] Final Memory: 10M/18M
> [INFO]
> What would cause such an error ? and most importantly how to fix it!
> cheers,
> Patrick
Re: [tycho-dev-1819] error while building jar [message #22015 is a reply to message #21971] |
Fri, 13 February 2009 02:02 |
Patrick Roumanoff Messages: 19 Registered: July 2009 |
thanks for your quick reply Igor,
I have figured it out: once the pom was genrated, I used Ctrl+F in the
eclipse POM editor to format it and the artifactId was split on two lines
thus reading
<artifactId>MyPlugin
</artifactId>
removing the extra line break solved the problem.
cheers,
Patrick
> can you check if C:workspacestychoMyPlugintarget gets created during
> folder.
> Regards,
> Igor
>> Hi,
>> C:workspacestychoMyPlugintargetMyPlugin-1.0.0-SNAPSHOT.jar
>> [ERROR]
>> Error stacktrace:
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> execution failed.
>> at
>> at
>> ... 16 more
>> assembling JAR
>> at
>> at
>> at
>> ... 17 more
>> creating jar: C:workspacestychoMyPlugintargetMyPlugin.jar (The
>> at
>> at
>> at
>> ... 19 more
>> C:workspacestychoMyPlugintargetMyPlugin-1.0.0-SNAPSHOT.jar (The
>> at
>> at
>> at
>> at
>> ... 21 more
>> [INFO]
>> [INFO] BUILD FAILED
>> [INFO]
>> [INFO]
>> cheers,
>> Patrick
Re: [tycho-dev-1819] error while building jar [message #22060 is a reply to message #22015] |
Fri, 13 February 2009 17:24 |
This looks like a bug in tycho or maven. I've opened
http://jira.codehaus.org/browse/MNGECLIPSE-1192 to track it.
> lines thus reading
> </artifactId>
> cheers,
> Patrick
>> the folder.
>> project that demonstrates the problem.
>> Regards,
>> Igor
>>> Hi,
>>> plugins, but then I hit this blocker and don't know where to look...
>>> [ERROR]
>>> Error stacktrace:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> execution failed.
>>> at
>>> at
>>> ... 16 more
>>> assembling JAR
>>> at
>>> at
>>> at
>>> ... 17 more
>>> the archive is probably corrupt but I could not delete it)
>>> at
>>> at
>>> at
>>> ... 19 more
>>> at
>>> at
>>> at
>>> at
>>> ... 21 more
>>> [INFO]
>>> [INFO] BUILD FAILED
>>> [INFO]
>>> [INFO]
>>> cheers,
>>> Patrick
Current Time: Thu Apr 25 20:27:24 GMT 2024
Powered by FUDForum. Page generated in 0.03270 seconds
