Home » Eclipse Projects » Plugin Development Environment (PDE) » Launching a "RunAs" Task from a Wizard
Re: Launching a "RunAs" Task from a Wizard [message #40443 is a reply to message #21851] |
Wed, 14 January 2009 15:24 |
Originally posted by: szchaler.acm.org
--------------000600030706050706080009
Look into the oAW source code. In the org.openarchitectureware.workflow
you'll find LaunchDelegate implementations that do what you need.
There's also code there that helps you understand how to call them. I
used something like the following:
ILaunchConfigurationType configType =
DebugPlugin.getDefault()
.getLaunchManager()
.getLaunchConfigurationType(
IWfLaunchConfigurationConstants.WORKFLOW_LAUNCH_CONFIGURATIO N_TYPE_ID);
ILaunchConfigurationWorkingCopy launchConfig =
configType.newInstance(null, "generate.oaw");
launchConfig.setAttribute(
IWfLaunchConfigurationConstants.ATTR_OAW_WORKFLOW_FILE,
workflowFile.getFullPath().toString());
IJavaLaunchConfigurationConstants.ATTR_PROJECT_NAME,
project.getName());
* Wait for build jobs here. For some reason, whenever I am not
* debugging this code, DebugUITools run into a NullPointerException
* when trying to do the waiting themselves
* This workaround code was copied from WorkflowLaunchDelegate.launch()
Job[] autoBuildJobs;
Job[] manBuildJobs;
do {
autoBuildJobs = Job.getJobManager().find(
ResourcesPlugin.FAMILY_AUTO_BUILD);
manBuildJobs = Job.getJobManager().find(
ResourcesPlugin.FAMILY_MANUAL_BUILD);
} while (autoBuildJobs.length > 0 || manBuildJobs.length > 0);
DebugUITools.launch(launchConfig, "run");
Notice, that this will trigger the workflow in a separate launch; that
is in a separate Job. I have still to figure out how to wait till its done.
Steffen
Karl Philipp wrote:
> I would like to integrate an available RunAs task (called "oaw
> workflow", BTW) in a wizard I currently implementing, that is the call
> of this task shall have the same effect to the eclipse project as the
> task would have manually launched by a user.
> In this context:
> 1. Can I identify how the "RunAS Oaw workflow" entry is attached
> to the underlying code (oaw plugin)?
> That is, I need the method call that is represented by "RunAS Oaw
> workflow".
> I guess that the menu item "RunAs" is an extension point.
> 2. ...
> Thanks in advance for your support
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to ECMDA-FA 2009, the 5th European Conference on
Model-Driven Architecture Foundations and Applications.
http://www.ecmda-fa.org/
Consider submitting to QoSA 2009, the 5th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider submitting to MiSE 2009, the 3rd International Workshop on
Models in Software Engineering
http://wikiserver.sse.cs.tu-bs.de/mise09
<html>
<head>
http-equiv="Content-Type">
</head>
Hi,<br>
<br>
used something like the following:<br>
<br>
<blockquote>
<pre>ILaunchConfigurationType configType =
.getLaunchManager()
project.getName());
Job[] manBuildJobs;
do {
</pre>
</blockquote>
done.<br>
<br>
Regards,<br>
<br>
Steffen<br>
<br>
Karl Philipp wrote:
<blockquote
cite="mid:ab5cc0f38aa7b88c28e8af6e13016798$1@www.eclipse.org"
type="cite">I would like to integrate an available RunAs task (called
"oaw workflow", BTW) in a wizard I currently implementing, that is the
call of this task shall have the same effect to the eclipse project as
the task would have manually launched by a user.
<br>
<br>
In this context:
<br>
<br>
<br>
Re: Launching a "RunAs" Task from a Wizard [message #588252 is a reply to message #21851] |
Steffen Zschaler Messages: 266 Registered: July 2009 |
.getLaunchManager()
project.getName());
Job[] manBuildJobs;
do {
Steffen
> In this context:
> workflow".
> 2. ...
<html>
<head>
</head>
Hi,<br>
<br>
<br>
<blockquote>
.getLaunchManager()
project.getName());
Job[] manBuildJobs;
do {
</pre>
</blockquote>
done.<br>
<br>
Regards,<br>
<br>
Steffen<br>
<br>
Karl Philipp wrote:
<blockquote
<br>
<br>
In this context:
<br>
<br>
<br>
Current Time: Thu Apr 25 06:03:54 GMT 2024
Powered by FUDForum. Page generated in 0.02676 seconds
