eclipse RCP and draw2d [message #224341] |
Fri, 13 October 2006 22:39 |
Originally posted by: cambazz.gmail.com
Is it possible to show a draw2d display inside an eclipse RCP view. I
tried, but I noticed when the display is instantiated, view gets a thread
error.
Best Regards,
C.B.
Re: eclipse RCP and draw2d [message #224371 is a reply to message #224341] |
Sun, 15 October 2006 16:07 |
Originally posted by: not_a_valid_email.appliedbiosystems.com
Hi Cam - yes it is possible. One example of how we've done it (v 3.1
and 3.2 libraries) is have our FigureCanvas embedded in a Composite
which gets created in the view (in createPartControl). Initially the
FigureCanvas is empty (it does have a visible draw2d label). Then, upon
the view receiving a particular event it's registered for, the
FigureCanvas is populated with the model provided it by the event. We
have not exprienced threading issues using that mechanism (yet).
What's your view's setup like? Also, which versions of RCP & GEF are
you using?
Good luck,
E.
Cam Bazz wrote:
> Hello,
> thread error.
> Best Regards,
> C.B.
Re: eclipse RCP and draw2d [message #224604 is a reply to message #224371] |
Tue, 17 October 2006 13:18 |
Hello E.;
I am very new to RCP and GEF. I am using the latest 3.2 calipso rcp and
gef.
Do you have any example code? I did not understand your explanation, but I
can read code.
Best Regards,
-C.B.
> you using?
> Good luck,
> E.
> Cam Bazz wrote:
>> Hello,
>> thread error.
>> Best Regards,
>> C.B.
Re: eclipse RCP and draw2d [message #224821 is a reply to message #224604] |
Thu, 19 October 2006 21:26 |
--------------000005020507010100060703
Hi Cam,
Attached is the source for a view incorporating draw2d. No magic going
on there. If you're still having a problem, please include the
Exception stack in your post.
Good luck,
E.
Cam Bazz wrote:
> Hello E.;
> and gef.
> but I can read code.
> Best Regards,
> -C.B.
name="ViewWithDraw2D.java"
Content-Disposition: inline;
filename="ViewWithDraw2D.java"
package standalone;
import org.eclipse.draw2d.Figure;
import org.eclipse.draw2d.FigureCanvas;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.RoundedRectangle;
import org.eclipse.draw2d.geometry.Rectangle;
import org.eclipse.jface.action.IMenuManager;
import org.eclipse.jface.action.IToolBarManager;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.ui.part.ViewPart;
public class ViewWithDraw2D extends ViewPart {
private FigureCanvas figureCanvas;
public static final String ID = "standalone.ViewWithDraw2D"; //$NON-NLS-1$
* Create contents of the view part
* @param parent
public void createPartControl(Composite parent) {
Composite container = new Composite(parent, SWT.NONE);
container.setLayout(new FillLayout());
this.figureCanvas = new FigureCanvas(container, SWT.NONE);
populateCanvas();
createActions();
initializeToolBar();
initializeMenu();
private void populateCanvas() {
IFigure root = new Figure();
root.setOpaque(false);
root.setBounds(new Rectangle(0, 0, 575, 350));
RoundedRectangle rect1 = new RoundedRectangle();
rect1.setBackgroundColor(Display.getCurrent().getSystemColor (SWT.COLOR_YELLOW));
rect1.setFill(true);
rect1.setBounds(new Rectangle(100, 100, 200, 150));
rect1.setOpaque(false);
root.add(rect1);
RoundedRectangle rect2 = new RoundedRectangle();
rect2.setBackgroundColor(Display.getCurrent().getSystemColor (SWT.COLOR_TITLE_BACKGROUND_GRADIENT));
rect2.setFill(true);
rect2.setBounds(new Rectangle(250, 150, 200, 150));
rect2.setOpaque(false);
root.add(rect2);
figureCanvas.setContents(root);
* Create the actions
private void createActions() {
// Create the actions
* Initialize the toolbar
private void initializeToolBar() {
IToolBarManager toolbarManager = getViewSite().getActionBars()
.getToolBarManager();
* Initialize the menu
private void initializeMenu() {
IMenuManager menuManager = getViewSite().getActionBars().getMenuManager();
public void setFocus() {
// Set the focus
--------------000005020507010100060703--
FUDForum. Page generated in 0.03643 seconds
