EMF property source provider in GEF? [message #223894] |
Fri, 06 October 2006 13:18 |
Originally posted by: jan.peknik.tietoenator.com
it seems that there is some 'Gotcha' in the using EMF property descriptor
constructed from IItemPropertySource generated by EMF. I found that many
people had
the same problem with some property value wrapper and getEditableValue()
something not being called,
which result in some class cast exception during editing properties.
Is there som easy way to use emf generated item providers as property
sources in GEF editor?
Thanks, J.Peknik
Re: EMF property source provider in GEF? [message #223899 is a reply to message #223894] |
Fri, 06 October 2006 17:02 |
Originally posted by: something.eclipse.org
It can be done, but I wouldn't call it easy. There are lots of posts
about different things people have tried. I personally found that for
my particular case, it was more trouble than it was worth and still
didn't provide much flexibility. If you have a simple model, it may be
fine.
adam
Jan Peknik wrote:
> Hello,
> people had
> Thanks, J.Peknik
FUDForum. Page generated in 0.03106 seconds
