XSLT transforms [message #223408] |
Tue, 04 November 2008 08:52 |
Originally posted by: paul.paharrison.net
I am using the WTL XSL tools feature 0.5.0 on OS X and have come across a
strange behaviour - it seems that xml comments in the input xml document
are not making it into the xml infoset that the xsl transformer sees, as
templates with a match="comment()" are never triggered - is this known
behaviour (which a configuration option to not ignore the comments) or is
it a bug?
Re: XSLT transforms [message #223437 is a reply to message #223408] |
Tue, 04 November 2008 14:40 |
Originally posted by: dcarver.starstandard.org
> a strange behaviour - it seems that xml comments in the input xml
> document are not making it into the xml infoset that the xsl transformer
> sees, as templates with a match="comment()" are never triggered - is
> this known behaviour (which a configuration option to not ignore the
> comments) or is it a bug?
Hmmm...I can repeate this. I'll open a bug to track this particular
issue to determine if it's a problem with XSL Tools or with the
processors. I've opened the following bug to track this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=253703
Question does this work if your run it outside of XSL Tools launch
configurations. i.e. setup an ant script to do the transform?
Dave
Re: XSLT transforms [message #223532 is a reply to message #223437] |
Thu, 06 November 2008 08:39 |
It does not appear to be a problem if my same script is run outside
eclipse -or indeed if I run the same script with the orangevolt xsl plugin.
Paul.
Re: XSLT transforms [message #223581 is a reply to message #223532] |
Thu, 06 November 2008 14:58 |
Yeah, I've been able to duplicate the issues, and you might want to
added yourself to the above bug to monitor it. I've targeted this for
an early 1.0M4 review and hopefully a fix.
Dave
Re: XSLT transforms [message #223764 is a reply to message #223532] |
Thu, 13 November 2008 04:50 |
Paul, I fixed this in tonights build. It'll be in the 1.0M4 milestone
build. More information in the bug report on what was causing the issue.
Dave
FUDForum. Page generated in 0.03064 seconds
