Re: Benefits of Standard make [message #223365 is a reply to message #223355] |
Wed, 10 September 2008 13:54 |
Originally posted by: subs._nospam_consertum.com
Wessam Emad wrote:
> Dear All,
> I'm currently doing a survey about why Standard makefiles could be a
> better option in some cases.
> Actually, I couldn't find any help or previous discussions about this
> topic so I need your help.
> What are standard make benefits than managed make? (C programming
> targeting embedded systems)
> Thanks in advance for your help.
Standard make offers complete flexibility about how you build yous
projects, including
- building complex systems
- running external tools that aren't supported by managed make
- build as many targets as you want in a single build
With standard make you have to write the makefile youself.
Some of these things you can mock-up with managed make, but it typically
isn't easy.
Derek
Re: Benefits of Standard make [message #223381 is a reply to message #223365] |
Wed, 10 September 2008 14:36 |
We use cmake to create the makefiles.
With cmake we work on different platforms, can switch compilers,
toggle a lot of featues (OpenMP, external libs, ...)
Fabian
Re: Benefits of Standard make [message #223389 is a reply to message #223365] |
Wed, 10 September 2008 14:48 |
Originally posted by: 4cs6fcg02.sneakemail.com
Derek schreef:
> Wessam Emad wrote:
>> Dear All,
> projects, including
Such as SWIG, which I use for JNI.
I took the makefile from Eclipse as base to write my own, but in the end
it looks very different.
Disadvantage: Eclipse takes care of all the platform-dependent stuff,
which you have to do yourself in the standard makefile.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Re: Benefits of Standard make [message #223412 is a reply to message #223397] |
Wed, 10 September 2008 15:55 |
Wessam Emad wrote:
> Can you please give me examples on some familiar tools that aren't
> supported by managed make? And when I can need to build many targets in
> a single build?
> Thanks for your help.
> Wessam
Easy - out-of-the-box, it doesn't support anything other than gcc, gas,
ld and ar. There may well be plugins for other tools, but this is the
standard set.
Derek
FUDForum. Page generated in 0.02507 seconds
