Home » Eclipse Projects » Nebula » To change the color of the image in the cell
To change the color of the image in the cell [message #21749] Wed, 03 January 2007 04:55 Go to next message
Originally posted by: krishna_24jan.yahoomail.com
Iam adding an image in a grid item by using griditem.setImage.
Now i want to change the color of the image with out changing the image.
Iam trying to use gridItem.setForeground but its not working.
Can i dynamically draw the image in the cell.Imean if i want a round image
can i dynamically draw in the code with out statically placing the image..?
or any other suggestions to sove my problem..?
Thanks in advance
krishna
Re: To change the color of the image in the cell [message #22019 is a reply to message #21749] Thu, 04 January 2007 16:26 Go to previous messageGo to next message
Chris Gross is currently offline Chris GrossFriend
The Grid will not alter the image for you. You can create your own
image and then set it to the item. For example:
Image image = new Image(display,16,16);
GC gc = new GC(image);
//draw stuff
gc.dispose();
gridItem.setImage(2,image);
-Chris
krishna wrote:
> image can i dynamically draw in the code with out statically placing the
> image..?
> Thanks in advance
> krishna
Re: To change the color of the image in the cell [message #29063 is a reply to message #21749] Tue, 13 February 2007 18:03 Go to previous message
Kathiravan  is currently offline Kathiravan Friend
Member
you have to create the image with the different color on your own.
BR,
surya.
krishna wrote:
> the image..?
> Thanks in advance
> krishna
Re: To change the color of the image in the cell [message #573872 is a reply to message #21749] Thu, 04 January 2007 16:26 Go to previous message
//draw stuff
gc.dispose();
-Chris
krishna wrote:
> image..?
> Thanks in advance
> krishna
Re: To change the color of the image in the cell [message #578500 is a reply to message #21749] Tue, 13 February 2007 18:03 Go to previous message
Member
BR,
surya.
krishna wrote:
> the image..?
> Thanks in advance
> krishna
Previous Topic:Maximize problem
Next Topic:[CompositeTable] Header and row control construction
Current Time: Sat Oct 24 01:38:59 GMT 2020
Powered by FUDForum. Page generated in 0.01983 seconds
