Home » Language IDEs » ServerTools (WTP) » Possibility to save *.xsd / *.wsdl files in respect to metamodel ?
Possibility to save *.xsd / *.wsdl files in respect to metamodel ? [message #223233] Wed, 29 October 2008 15:06 Go to next message
Tim Brömme is currently offline Tim BrömmeFriend
as the topic says, I'm asking myself if it is possible to save / convert /
etc.
*.wsdl and *.xsd files in a way, that they correspond to the their
ecore-models:
org.eclipse.wst.wsdl/model/WSDL.ecore
org.elipcse.xsd/model/XSD.ecore
I was wondering where these metamodels are used ?
Are they the foundation of the graphical editors for XSD and WSDL ?
Are the graphical editors GMF / GEF based ?
Thanks is advance,
Tim
Re: Possibility to save *.xsd / *.wsdl files in respect to metamodel ? [message #223245 is a reply to message #223233] Wed, 29 October 2008 15:28 Go to previous messageGo to next message
Tim,
You've asked related questions in the XSD newsgroup. The models to
which you refer were used to generate an API, like the one in
org.eclipse.xsd which is used to read and write *.xsd files and convert
them to an structured internal representation for manipulating the
in-memory instances. So yes, it's possible, and that's what they're
designed to support. And yes, the editors are built on top of these
models, because they provide the deep semantic "view". The graphical
editors use GEF, but I don't believe they are GMF-based..
Tim Brömme wrote:
> convert / etc.
> ecore-models:
> I was wondering where these metamodels are used ? Are they the
> foundation of the graphical editors for XSD and WSDL ? Are the
> Thanks is advance, Tim
Ed Merks
Re: Possibility to save *.xsd / *.wsdl files in respect to metamodel ? [message #223252 is a reply to message #223245] Wed, 29 October 2008 15:58 Go to previous message
Hi Ed,
thanks for your fast reply. You are right, the post in the
xsd newsgroup is directly connected to this issue.
You helped a lot!
Previous Topic:How to create a web service client (!) jar archive from Eclipse?
Next Topic:Question on setting up a static web project
Current Time: Tue Apr 13 01:37:47 GMT 2021
Powered by FUDForum. Page generated in 0.01691 seconds
