Home » Newcomers » Newcomers » [SOLVED]Startup Error
[SOLVED]Startup Error [message #1311885] Thu, 24 April 2014 02:15 Go to next message
Waqas Nadeem is currently offline Waqas NadeemFriend
Hello I have been using eclipse for awhile and havn't had any issues but today when I start Eclipse I get the error that is attached to this post. I searched online but was not able to find any solution. I normally use the ADT bundle but none of the eclipse start including the one from eclipse.org Thanks in advance.
i62.tinypic.com/33athug[DOT]jpg sorry can't post links yet.
[Updated on: Fri, 25 April 2014 03:31]
Report message to a moderator
Re: Startup Error [message #1312689 is a reply to message #1311885] Thu, 24 April 2014 12:49 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
See the "sticky" post that the top of this forum titled "Trouble getting Eclipse to run? READ THIS FIRST"
Re: Startup Error [message #1312719 is a reply to message #1312689] Thu, 24 April 2014 13:08 Go to previous messageGo to next message
Eric Rizzo wrote on Thu, 24 April 2014 08:49
Just tried editing the eclipse.ini file to point to where javaw.exe is located but I still get the error. I attached the updated error showing that the line was added. I don't understand what happened everything was working fine a few days ago and I was able to code before. Thanks in advance.
index.php/fa/17985/0/
  • Attachment: Capture.JPG
    (Size: 127.03KB, Downloaded 244 times)
Re: Startup Error [message #1312903 is a reply to message #1312719] Thu, 24 April 2014 15:25 Go to previous messageGo to next message
You're using 64-bit Eclipse; are you sure the JRE is also 64-bit? Verify by doing <path-to-JRE>\bin\java -version
Re: Startup Error [message #1313036 is a reply to message #1312903] Thu, 24 April 2014 17:04 Go to previous messageGo to next message
Eric Rizzo wrote on Thu, 24 April 2014 11:25
yes because the Java that is installed on the computer is 64 bit and is located in Program files instead of program files(x86). Thanks for trying to help me fix this issue.
Re: Startup Error [message #1313839 is a reply to message #1313036] Fri, 25 April 2014 03:29 Go to previous message
Figured out my error Malwarebytes Anti-Exploit Beta apparently stops some process from running which Eclipse needs. looking at the log of Malwarebytes for the blocked process nothing shows. Thanks for helping me solve this issue.
[Updated on: Fri, 25 April 2014 03:30]
Previous Topic:Eclipse forum login fails
Next Topic:Blue Screen of Death on Multiple version of Eclipse on Start Up
Current Time: Thu Nov 26 19:19:15 GMT 2020
Powered by FUDForum. Page generated in 0.03810 seconds
