Home » Eclipse Projects » BPMN 2.0 Modeler » Custom Task and Append button
Custom Task and Append button [message #1310797] Wed, 23 April 2014 12:01 Go to next message
Damien Dussol is currently offline Damien DussolFriend
I have created a custom task to define a "None End Event". My class extends CustomShapeFeatureContainer and I override getCreateFeature.
    public ICreateFeature getCreateFeature(final IFeatureProvider fp1)
        return new CreateCustomShapeFeature(fp1)
            public String getCreateDescription()
                return "Create a None End Event";
My problem is : when the cursor is on the Custom task , I can see "Append Event", "Append Gateway","Append Activity" buttons. My custom Task define an end event, so I don't need these buttons. How can I remove these buttons ?
Thanks for your help.
Damien
Re: Custom Task and Append button [message #1310873 is a reply to message #1310797] Wed, 23 April 2014 13:00 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
Hi Damien,
You need to override getCustomFeatures(IFeatureProvider) in your CustomShapeFeatureContainer and either call the superclass and cull out the Features you don't want, or simply return an empty array.
HTH,
Bob
Re: Custom Task and Append button [message #1311037 is a reply to message #1310873] Wed, 23 April 2014 15:03 Go to previous messageGo to next message
Hi Bob
I did it but it doesn't work.
    public ICustomFeature[] getCustomFeatures(IFeatureProvider fp)
        ICustomFeature[] customFeature= new ICustomFeature[0];
        return customFeature;
I have several Custom task (several defines end event none, others defines start event none).
I see it is BPMNFeatureProvider class which call getCustomFeatures for each custom task. If i have several Custom task, BPMNFeatureProvider .getCustomFeatures will return all custom features for all custom task, i am wrong ?
Damien
Re: Custom Task and Append button [message #1311581 is a reply to message #1311037] Wed, 23 April 2014 22:07 Go to previous message
Yes, you are absolutely correct - this is a BUG!
Please file a bug report and I'll fix this ASAP.
Thanks!
Bob
Previous Topic:Support of XMI or other formats in Import
Next Topic:Impossible to create a SequenceFlow if the target is a Catch Event
Current Time: Mon Jul 06 03:53:51 GMT 2020
Powered by FUDForum. Page generated in 0.01512 seconds
