Re: Urgent - Creating a WSDL Model from string [message #221816 is a reply to message #221800] |
Thu, 25 September 2008 11:12 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------080909010901020105000404
Keshavrao,
Does WSDLResourceImpl have methods like XSDResourceImpl does for loading
from an InputSource?
public final void load(InputSource inputSource, Map<?, ?> options)
throws IOException
Failing that, EMF has added support for "new
URIConverter.ReadableInputStream(<xml-string>)" which wraps a string or
reader to make it work like an InputStream. And XSDResourceImpl has
specialized support to unwrap such a stream so that it can efficiently
process the characters directly.
protected void doLoad(InputStream inputStream, Map<?, ?> options)
throws IOException
InputSource inputSource =
inputStream instanceof URIConverter.ReadableInputStream ?
new
InputSource(((URIConverter.ReadableInputStream)inputStream). asReader())
new InputSource(inputStream);
if (getURI() != null)
String id = getURI().toString();
inputSource.setPublicId(id);
inputSource.setSystemId(id);
doLoad(inputSource, options);
WSDLResourceImpl should support the same type of thing, but even if it
doesn't this approach should still work, albeit less efficiently than
unwrapping the stream.
Keshavrao wrote:
> Hello all,
> I am trying to create a WSDL model from the string and i used
> the below method
> WSDLReader newWSDLReader;
> newWSDLReader = WSDLFactory.newInstance().newWSDLReader();
> return (newWSDLReader.readWSDL(null, new InputSource(new
> StringReader(contents))));
> but the Definition object obtained this way is returning the schema
> sections as DOM elements and not as the ecore XSD Model.
> But when i create using the below method
> private Definition readService(final IFile file){
> final String wsdlURL = file.getLocationURI().getPath();
> final ResourceSet resourceSet = new ResourceSetImpl();
> WSDLResourceImpl wsdlr = (WSDLResourceImpl)
> resourceSet.getResource(URI.createFileURI(wsdlURL),true);
> return wsdlr.getDefinition();
> i get the definition object with schema sections as
> XSDSchemaExtensibilityElement
> Can anyone help me finding the reason or it would be great if you
> could tell
> me, how get the defintion model which would be same as the resource
> approach
> but with the String contents of WSDLs
> Thanks and regards,
> Keshav Veerapaneni.
<html>
<head>
http-equiv="Content-Type">
</head>
Keshavrao,<br>
<br>
loading from an InputSource?<br>
<br>
Ed Merks
Re: Urgent - Creating a WSDL Model from string [message #221833 is a reply to message #221800] |
Thu, 25 September 2008 18:23 |
Originally posted by: valentinbaciu.hotmail.com
How about trying to create the WSDL4J WSDLFactory like this:
WSDLFactory factory = WSDLPlugin.INSTANCE.createWSDL4JFactory();
This factory should give you a WSDL reader that uses the WSDL EMF model to
load a Definition. The model should be configured with the extensibility
element factory that creates XSDSchemaExtensibilityElement when it
encounters an inline schema.
Regards, Valentin
"Keshavrao " <keshavrao.veerapaneni@sap.com> wrote in message
news:41eb3605474822c90649faa527f402d7$1@www.eclipse.org...
> Hello all,
> I am trying to create a WSDL model from the string and i used the
> below method
> Can anyone help me finding the reason or it would be great if you could
> tell
> approach
> Thanks and regards,
> Keshav Veerapaneni.
FUDForum. Page generated in 0.02380 seconds
