Contributing a Web service CLIENT runtime with UI in WTP [message #221544] |
Wed, 17 September 2008 21:47 |
I need to offer a web service runtime that influences the generation of
clients.
The "Contributing a Web service runtime with UI in WTP"
( http://www.eclipse.org/webtools/jst/components/ws/documents/ ContributingWebServiceRTWithUI.html)
was very helpful but was limited to a discussion of extending the
org.eclipse.jst.ws.consumption.ui.serviceRuntimes. Regardless, it seemed a
very a good place to start in an attempt to extend
org.eclipse.jst.ws.consumption.ui.clientRuntimes. Unfortunately, I am
having a problem where the widgets are being created without the model being
retrieved from the command class identified by
DataMappingRegistry.addMapping. As a result, I have a null model in my
widgets, which isn't good.
I have added a clientRuntimes extension to this example and provide it as an
attachment to this posting. If you attempt to generate a client with "Web
service example runtime", you will encounter a nullpointer when the
contributed UI is built.
I have attempted to trace the underlying framework code but I am not well
acquainted with it and have been stuck longer than I want to admit.
Help would be greatly appreciated.
Changes to the sample:
1) Created ExampleWebserviceClient.java which creates two pre-existing
commands.
2) Modified ExampleRuntime.getWebServiceClient to return
3) Added the org.eclipse.jst.ws.consumption.ui.clientRuntimes extension in
the plugin.xml
Thank you,
John
Re: Contributing a Web service CLIENT runtime with UI in WTP [message #221584 is a reply to message #221544] |
Thu, 18 September 2008 22:39 |
I neglected to try this on ganymede prior to my post. It does work on 3.4.
I will see if there are any updates available to 3.3 in hopes that I can
offer the customization there too.
Thank you,
>clients.
> a very a good place to start in an attempt to extend
> being retrieved from the command class identified by
> an attachment to this posting. If you attempt to generate a client with
> "Web service example runtime", you will encounter a nullpointer when the
> commands.
> the plugin.xml
> Thank you,
> John
Re: Contributing a Web service CLIENT runtime with UI in WTP [message #222520 is a reply to message #221584] |
Tue, 30 September 2008 20:52 |
Kathy Chan Messages: 93 Registered: July 2009 |
Member |
Hi John,
The doc you refer to is the right documentation to use for contributing Web
service service runtime and client runtime. You could look at the other
examples in the org.eclipse.jst.ws.axis.* and org.eclipse.jst.ws.axis2.*
plugins under the Webservices component for examples of how the client
runtimes are defined.
Nice to hear that you got it working with WTP 3.0. I assume you were having
trouble originally with WTP 2.0.x? If that's the case, I would suggest you
move to WTP 3.0.x since we had made quite a bit of fixes and enhancements in
that release.
Kathy Chan
"John Palof" <john.palof@soa.com> wrote in message
news:gaulaa$d7o$1@build.eclipse.org...
> Thank you,
>>clients.
>> seemed a very a good place to start in an attempt to extend
>> commands.
>> in the plugin.xml
>> Thank you,
>> John
FUDForum. Page generated in 0.03216 seconds
