Home » Language IDEs » ServerTools (WTP) » Contributing a Web service CLIENT runtime with UI in WTP
Contributing a Web service CLIENT runtime with UI in WTP [message #221544] Wed, 17 September 2008 17:47 Go to next message
I need to offer a web service runtime that influences the generation of
clients.
The "Contributing a Web service runtime with UI in WTP"
( http://www.eclipse.org/webtools/jst/components/ws/documents/ ContributingWebServiceRTWithUI.html)
was very helpful but was limited to a discussion of extending the
org.eclipse.jst.ws.consumption.ui.serviceRuntimes. Regardless, it seemed a
very a good place to start in an attempt to extend
org.eclipse.jst.ws.consumption.ui.clientRuntimes. Unfortunately, I am
having a problem where the widgets are being created without the model being
retrieved from the command class identified by
DataMappingRegistry.addMapping. As a result, I have a null model in my
widgets, which isn't good.
I have added a clientRuntimes extension to this example and provide it as an
attachment to this posting. If you attempt to generate a client with "Web
service example runtime", you will encounter a nullpointer when the
contributed UI is built.
I have attempted to trace the underlying framework code but I am not well
acquainted with it and have been stuck longer than I want to admit.
Help would be greatly appreciated.
Changes to the sample:
1) Created ExampleWebserviceClient.java which creates two pre-existing
commands.
2) Modified ExampleRuntime.getWebServiceClient to return
3) Added the org.eclipse.jst.ws.consumption.ui.clientRuntimes extension in
the plugin.xml
Thank you,
John
Re: Contributing a Web service CLIENT runtime with UI in WTP [message #221584 is a reply to message #221544] Thu, 18 September 2008 18:39 Go to previous messageGo to next message
I neglected to try this on ganymede prior to my post. It does work on 3.4.
I will see if there are any updates available to 3.3 in hopes that I can
offer the customization there too.
Thank you,
>clients.
> a very a good place to start in an attempt to extend
> being retrieved from the command class identified by
> an attachment to this posting. If you attempt to generate a client with
> "Web service example runtime", you will encounter a nullpointer when the
> commands.
> the plugin.xml
> Thank you,
> John
Re: Contributing a Web service CLIENT runtime with UI in WTP [message #222520 is a reply to message #221584] Tue, 30 September 2008 16:52 Go to previous messageGo to next message
Hi John,
The doc you refer to is the right documentation to use for contributing Web
service service runtime and client runtime. You could look at the other
examples in the org.eclipse.jst.ws.axis.* and org.eclipse.jst.ws.axis2.*
plugins under the Webservices component for examples of how the client
runtimes are defined.
Nice to hear that you got it working with WTP 3.0. I assume you were having
trouble originally with WTP 2.0.x? If that's the case, I would suggest you
move to WTP 3.0.x since we had made quite a bit of fixes and enhancements in
that release.
Kathy Chan
"John Palof" <john.palof@soa.com> wrote in message
news:gaulaa$d7o$1@build.eclipse.org...
> Thank you,
>>clients.
>> seemed a very a good place to start in an attempt to extend
>> commands.
>> in the plugin.xml
>> Thank you,
>> John
Re: Contributing a Web service CLIENT runtime with UI in WTP [message #223290 is a reply to message #221544] Thu, 30 October 2008 08:53 Go to previous message
Hi John,
I am currently updating the sample & docs related to contributing runtimes
and interested to see the problems you had contributing your client
runtime in the attachment you posted. I cannot download the attachment as
seems to have become corrupted in your post? If you could try and
reattach or let me know how to access?
Previous Topic:Contributing actions to XML editor popup/context menu
Next Topic:What to specify for "servlet" in the web.xml for a web service: The Implementation or Inte
Current Time: Sun Nov 02 07:06:23 EST 2025
Powered by FUDForum. Page generated in 0.02591 seconds
