Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Always getting result as 'true' in 'isUnique' operation
Always getting result as 'true' in 'isUnique' operation [message #21396] |
Mon, 06 February 2006 05:56 |
Shrawanika Messages: 16 Registered: July 2009 |
With the following isUnique() operations, I am always getting result
as true. Is this incorrect or my usage is incorrect?
Set{1,1,3,2,4,1}->isUnique(1) : true
Bag{1,1,3,2,4,1}->isUnique(1) : true
Sequence{1,1,3,2,4,1}->isUnique(1) : true
OrderedSet{1,1,3,2,4,1}->isUnique(1) : true
Even with this also:
Set{1,1,3,2,4,1}->isUnique(8) : true
-Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #21405 is a reply to message #21396] |
Mon, 06 February 2006 14:05 |
Hi, Shrawanika,
I'm afraid that the answer is "yes and yes." :-)
Your usage is incorrect and the OCL interpreter appears to have a bug.
The isUnique iterator determines whether the body expression has a different
value for every element in the collection. Your expressions should be
formulated thusly (e.g):
Bag{1,1,3,2,4,1}->isUnique(e | e = 1)
Your examples should all result in "false" by the very nature of the body
expression being a constant. Whatever the collection value and whatever
the iterator expression, the interpreter is always answering true.
Care to add to your list of reported bugzillae?
Christian
Shrawanika wrote:
> -Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #21412 is a reply to message #21405] |
Tue, 07 February 2006 04:40 |
Hi Christian,
As you told me I tried the expressions formulated like this also:
But still the result is true always:
Set{1,1,3,2,4,1}->isUnique(e | e = 1) : true
Bag{1,1,3,2,4,1}->isUnique(e | e = 1) : true
Sequence{1,1,3,2,4,1}->isUnique(e | e = 1) : true
OrderedSet{1,1,3,2,4,1}->isUnique(e | e = 1) : true
Set{1,1,3,2,4,1}->isUnique(e | e = 8) : true
Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #21431 is a reply to message #21405] |
Wed, 08 February 2006 02:20 |
Originally posted by: jos.warmer.klasse.nl
If you are trying to check that the elements in the collections are
unique you need to write:
Bag{1,1,3,2,4,1}->isUnique(e | e)
because the body expression now evaluates to the value of the elements
in the collection this shoudl result in 'true' is each element is unique.
If you write
The body evaluates to a boolean value and it will therefore check
whether this boolean value is unique.
Jos
Christian W. Damus wrote:
> Hi, Shrawanika,
> Christian
> Shrawanika wrote:
>> Hi,
>> -Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #21455 is a reply to message #21431] |
Tue, 07 February 2006 17:48 |
Ouch! Good point.
There being only two boolean values, any collection of more than two
elements will guarantee a result of false.
Of course, this doesn't make our bug go away because the result will still
always be true! :-D
Christian
Jos Warmer wrote:
> If you write
> Jos
Re: Always getting result as 'true' in 'isUnique' operation [message #21468 is a reply to message #21405] |
Wed, 08 February 2006 04:44 |
I tried all these:
If element 1 is checked for it's uniqueness in collection:
Checking if all elements are unique or not:
Bag{1,1,3,2,4,1}->isUnique(e | e ) : true
Checking as per as specified usage:
8 is not in collection , expression should fail or result in false:
Bag{1,1,3,2,4,1}->isUnique(e | e = 8) : true
So, I raised https://bugs.eclipse.org/bugs/show_bug.cgi?id=126861
Thanks and Regards,
Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #21750 is a reply to message #21455] |
Fri, 10 February 2006 03:30 |
Christian,
Yep, it's still a bug.
Jos
> Ouch! Good point.
> always be true! :-D
> Christian
> Jos Warmer wrote:
>> Hi,
>> If you write
>> Jos
Re: Always getting result as 'true' in 'isUnique' operation [message #565955 is a reply to message #21396] |
Hi, Shrawanika,
Christian
Shrawanika wrote:
> -Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #565989 is a reply to message #21405] |
Hi Christian,
Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #566033 is a reply to message #21405] |
Jos Warmer Messages: 66 Registered: July 2009 |
Member |
If you write
Jos
> Hi, Shrawanika,
> Christian
> Shrawanika wrote:
>> Hi,
>> -Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #566162 is a reply to message #21431] |
Ouch! Good point.
always be true! :-D
Christian
Jos Warmer wrote:
> If you write
> Jos
Re: Always getting result as 'true' in 'isUnique' operation [message #566228 is a reply to message #21405] |
I tried all these:
Thanks and Regards,
Shrawanika
Re: Always getting result as 'true' in 'isUnique' operation [message #566409 is a reply to message #21455] |
Member |
Christian,
Jos
> Ouch! Good point.
> always be true! :-D
> Christian
> Jos Warmer wrote:
>> Hi,
>> If you write
>> Jos
Current Time: Thu Apr 18 18:18:44 GMT 2024
Powered by FUDForum. Page generated in 0.02634 seconds
