Getting/Setting EReferences of a EMF model instance in a TableViewer with ComboBox [message #1304348] |
Sat, 19 April 2014 20:56 |
Emre T Messages: 119 Registered: April 2013 |
Hello!
I need to set and get values of EReferences of an EMF model instance, for which I use a self implemented UI mainly in Jface/SWT. In it there is a table viewer that listens to active editors, where I can set/get the values of certain data types, such as from primitive ones to Strings or Enums. To do that I have extended the EditingSupport, which the TableColumns are using by calling the setEditingSupport()-method.
For Boolean and Enum values I use ComboBoxCellEditor and for all other types the simple TextCellEditor. But they are all EAttributes and I am kind of lost when it comes to exploiting the EReferences of an EMF model. What I need to achieve is actually the same as what the Eclipse Properties View does. Using also a ComboBoxCellEditor for accessible elements that can be referenced by the EReference properties of a model, after other necessary models are reloaded as a model.
So, my question is whether it is possible to get this done, just like by the other EStructuralFeatures and in an EditingSupport? I couldn't find any materials directly regarding this issue. Any help will be appreciated.
Thanks!
FUDForum. Page generated in 0.03437 seconds
