Re: Drag&Drop without moving the Node ... [message #1311155 is a reply to message #1303461] |
Wed, 23 April 2014 16:31 |
I reproduced your issue using an Ecore model. My "real containers" are represented by EPackages containing EClasses. My "fake container" are EClasses displaying their "eSuperTypes" in a list container. Then, my drag and drop tool simple updates the eSuperType reference.
I need to investigate a little but that looks like a bug. As the dragged element is still displayed in its initial container, we should not remove and recreated it.
Steve
Steve Monnier - Obeo Canada
Re: Drag&Drop without moving the Node ... [message #1384807 is a reply to message #1384801] |
Mon, 02 June 2014 08:30 |
Le 02/06/2014 09:51, Nikolay Manolov a écrit :
> Drag N Drop in general has two functions. One is "move" and the other is
> "copy".
> The described case above kind of falls into the second category and as
> such I think it should be considered a bug.
The enhancement https://bugs.eclipse.org/bugs/show_bug.cgi?id=433362
has been created to dealt with this issue.
> A nice enhancement would be to have the drag N drop not just for
> containers but also for nodes, so that elements can be associated with
> each other or values/references can be set.
It is already the case, in the VSM editor, you can specify drag and drop
tools with Nodes or Containers as dragged elements and Nodes, Containers
or Diagram as drop targets.
Maxime
Maxime Porhel - Obeo
FUDForum. Page generated in 0.03203 seconds
