Home » Newcomers » Newcomers » Eclipse writes to Dropbox folder(Eclipse tries to store 2 files in the Dropbox folder)
Eclipse writes to Dropbox folder [message #1302314] Fri, 18 April 2014 17:06 Go to next message
alex alexander is currently offline alex alexanderFriend
Search for "Dropbox" on this forum didn't show anything.
During first run, Eclipse Standard 4.3.2 creates 2 files in the dopbox folder.
"...\Dropbox\shellext\l\53514c92"
and
"...\Dropbox\shellext\l\535001e2"
(I'm not sure if it's safe to post their contents here so I won't for now.)
Anyone knows purpose of this?
Re: Eclipse writes to Dropbox folder [message #1302561 is a reply to message #1302314] Fri, 18 April 2014 20:29 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
What makes you say that Eclipse is creating those files? Eclipse itself doesn't know anything about Dropbox. Perhaps you have installed a third-party plugin that might be doing that?
Re: Eclipse writes to Dropbox folder [message #1302634 is a reply to message #1302561] Fri, 18 April 2014 21:27 Go to previous messageGo to next message
Before running eclipse, i have set the %APPDATA% to a custom location.
Described files appear in that custom location, available only to eclipse.
No plugins, clean fresh install.
I probably should have mention it straight away, but now I realised opening a project from dropbox folder. However this still does not explain what's happening:
set APPDATA=...\eclipse\data
eclipse.exe
* open project from ...\UserFolder\Dropbox\Folder\Folder\Project1\ *
* new files appear in ...\eclipse\data\Dropbox\shellext\l *
I'm just trying to understand this behavior.
Thanks for reply,
[Updated on: Fri, 18 April 2014 21:28]
Report message to a moderator
Re: Eclipse writes to Dropbox folder [message #1303579 is a reply to message #1302634] Sat, 19 April 2014 10:26 Go to previous messageGo to next message
Luuk 34 is currently offline Luuk 34Friend
On 18-4-2014 23:27, alex alexander wrote:
> Quote:
> Quote:
> eclipse.exe
> I'm just trying to understand why this is happening.
> Thanks for reply,
This is not a problem created by Eclips
'Dropbox' creates files in %appdata%Dropbox .....
If i do this:
set APPDATA=c:\temp
"c:\Program Files (x86)\Notepad++\notepad++.exe"
c:\users\luuk\dropbox\test.txt
than i also see a folder c:\temp\Dropbox being created.... ;)
Re: Eclipse writes to Dropbox folder [message #1303617 is a reply to message #1303579] Sat, 19 April 2014 10:58 Go to previous message
Thank you Luuk!
Previous Topic:Eclipse GUI too small on ultrabook
Next Topic:error 404
Current Time: Sun Jun 20 17:19:51 GMT 2021
Powered by FUDForum. Page generated in 0.02752 seconds
