Direct Edit - Adding and Removing Edit Parts [message #219562] |
Tue, 18 July 2006 16:55  |
Originally posted by: Daniel.Rozeboom.cda.canon.com
Hi there,
I've seen a few fragments around for Direct Edit but it seems like a lot
is still up in the air. What I'm trying to do is implement a situation
where I can direct edit a section of text in an edit part, but this direct
editing should also allow the user to insert other types of edit parts
(containing images, widgets, whatever) in the text. I suppose this idea is
similar to a WYSIWIG editor inside an edit part, but not quite so robust.
Is this feasible? If it will mean trying to write a whole new section
of Draw2D or what have you, I can probably attempt to implement it in a
pop-up dialog if it saves some trouble. But I'm just not entirely clear on
how the text facilities of Draw2D and the capabilities of direct edit will
fit into the picture here. Does anyone have some suggestions as to the best
way this can be accomplished, or can you pinpoint certain features that I
will have a very difficult time implementing through the current GEF/Draw2D
facilities? Thanks in advance.
- Daniel
Re: Direct Edit - Adding and Removing Edit Parts [message #219608 is a reply to message #219562] |
Wed, 19 July 2006 15:57   |
rich text cell editing is something that the GEF text work considers a
requirement. Unfortunately, that work is still isolated in an example due to
lack of feedback and clients to help establish the API.
At one point, we had the Logic example performing direct edit without direct
edit manager. In other words, the TextSelectionTool simple placed the caret
in the note object and started typing.
"Daniel Rozeboom" <Daniel.Rozeboom@cda.canon.com> wrote in message
news:e9j3q5$qcj$1@utils.eclipse.org...
> Hi there,
> lot is still up in the air. What I'm trying to do is implement a
> situation where I can direct edit a section of text in an edit part, but
> this direct editing should also allow the user to insert other types of
> edit parts (containing images, widgets, whatever) in the text. I suppose
> this idea is similar to a WYSIWIG editor inside an edit part, but not
> quite so robust.
> on how the text facilities of Draw2D and the capabilities of direct edit
> will fit into the picture here. Does anyone have some suggestions as to
> the best way this can be accomplished, or can you pinpoint certain
> features that I will have a very difficult time implementing through the
> current GEF/Draw2D facilities? Thanks in advance.
> - Daniel
Re: Direct Edit - Adding and Removing Edit Parts [message #219614 is a reply to message #219608] |
Wed, 19 July 2006 21:13   |
So basically there's no good way to do this? Would it be helpful for me to
see this version of the Logic example you're referring to, or no? Thanks in
advance.
- Daniel
"Randy Hudson" <none@us.ibm.com> wrote in message
news:e9lkpf$lvd$1@utils.eclipse.org...
> to lack of feedback and clients to help establish the API.
> direct edit manager. In other words, the TextSelectionTool simple placed
> the caret in the note object and started typing.
>> Hi there,
>> quite so robust.
>> - Daniel
Re: Direct Edit - Adding and Removing Edit Parts [message #219961 is a reply to message #219614] |
Mon, 24 July 2006 15:25   |
news:e9m79g$j56$1@utils.eclipse.org...
> to see this version of the Logic example you're referring to, or no?
> Thanks in advance.
That version is unreleased, as it depended on unreleased GEF code. Clients
have created entire HTML editors using GEF, so there are *ways* to do
things. There is a good way, and it requires a lot of work. It's a question
of what is right for you, and how much work will it take.
Since your use case is probably a closed world, you have an easier effort
than it takes to design an API that can work for all GEF clients, regardless
of what they are trying to do. You should look at the text example.
Re: Direct Edit - Adding and Removing Edit Parts [message #220135 is a reply to message #219961] |
Tue, 25 July 2006 17:43  |
10-4. I think to save myself twenty headaches, a slightly simplified (but
more specialized) solution will probably work for me. Thanks.
- Daniel
news:ea2oop$35a$1@utils.eclipse.org...
>> Thanks in advance.
> question of what is right for you, and how much work will it take.
> regardless of what they are trying to do. You should look at the text
> example.
FUDForum. Page generated in 0.03534 seconds
