Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP 4.0, repackaging of classes, where are these now?
TPTP 4.0, repackaging of classes, where are these now? [message #21278] Mon, 11 July 2005 07:13 Go to next message
Originally posted by: varaya.syamanond.centrelink.gov.au
Hi all,
I'm trying to get the tutorial code from EclipseCon to work using TPTP
4.0. I read from earlier posts that there have been repackaging of the
plugins. I was wondering where I can find the following now:
import org.eclipse.hyades.models.hierarchy.HierarchyFactory;
import org.eclipse.hyades.models.hierarchy.TRCAgent;
import org.eclipse.hyades.models.hierarchy.TRCAgentProxy;
import org.eclipse.hyades.models.hierarchy.TRCMonitor;
import org.eclipse.hyades.models.hierarchy.TRCNode;
import org.eclipse.hyades.models.hierarchy.TRCProcessProxy;
import org.eclipse.hyades.models.hierarchy.util.HierarchyResourceSe tImpl;
import org.eclipse.hyades.statistical.ui.EditorPlugin;
as these are showing up as errors when I import the tutorial code.
Thank you very much for your help!
Sylvia
Re: TPTP 4.0, repackaging of classes, where are these now? [message #21292 is a reply to message #21278] Mon, 11 July 2005 09:20 Go to previous message
Antony Miguel is currently offline Antony MiguelFriend
Member
Hi Sylvia,
All the models have been grouped into a single plugin called
org.eclipse.tptp.platform.models
If you import that plugin then you should get access to all the models.
Also, the EditorPlugin class in (org.eclipse.hyades.statistical.ui) has
been renamed to UiPlugin - you'll have to change the code to reference
UiPlugin instead of EditorPlugin.
cheers
Antony
Sylvia S wrote:
> Hi all,
> Sylvia
Previous Topic:TPTP via update manager?
Next Topic:Best TPTP version for eclipse 3.1
Current Time: Fri Sep 30 17:09:15 GMT 2022
Powered by FUDForum. Page generated in 0.01566 seconds
