Re: [ECP/EMFStore] with MySQL instead of MongoDB [message #1314138 is a reply to message #1312020] |
Fri, 25 April 2014 07:28 |
if you haven't included the EMFStore mongodb plugins in your run-configuration the projects will be stored as XMI in your user-home directory in the .emfstore -folder.
In order to store them with mongodb you will have to add the EMFStore mongodb plugins to your runconfig and their dependencies. Those are:
org.eclipselabs.emf.query.simple
org.eclipselabs.mongo
org.eclipselabs.mongo.emf
org.eclipselabs.mongo.emf.builders
org.eclipselabs.mongo.emf.converter
org.eclipselabs.mongo.emf.ext
org.eclipselabs.mongo.emf.query.simple
org.eclipselabs.mongo.emf.streams
org.eclipse.equinox.ds
org.eclipse.equinox.cm
Also make sure that equinox.ds and *.cm have autostart set to true and a start-level of 1.
If you are missing those dependencies in your target platform, take at look at the emfstore.target.
EMFStore expects that there is a running mongodb instance it can connect to. By default it will look for an instance running on the localhost.
Cheers
Johannes
Johannes Faltermeier
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.03082 seconds
