Home » Language IDEs » ServerTools (WTP) » Unable to install XSL tooling 0.5.0.v200806220600 from update site
Unable to install XSL tooling 0.5.0.v200806220600 from update site [message #218716] |
Mon, 04 August 2008 11:45 |
Originally posted by: joerg.von.frantzius.artnology.com
--------------020306080201080704060907
when I try to install current XSL tooling 0.5.0.v200806220600 from the
WTP update site, my Eclipse 3.4's P2 will complain about the following:
Cannot complete the request. See the details.
XSL Feature (Incubating) is already installed, so an update will be
performed instead.
Cannot find a solution satisfying the following requirements
Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.apache.commons.logging/[1.0.4. v20080605-1930,1.0.4.v20080605-1930]].
Does anybody know how I can satisfy that dependency (the easy way ;) ?
Or should it be available on the WTP update site as well?
J
Re: Unable to install XSL tooling 0.5.0.v200806220600 from update site [message #218756 is a reply to message #218716] |
Mon, 04 August 2008 13:42 |
Originally posted by: dcarver.starstandard.org
Jörg von Frantzius wrote:
> performed instead.
Apache commons logging should have be included. What you can do is
grab the version you need from Orbit, and drop it into your plugins folder.
http://download.eclipse.org/tools/orbit/downloads/drops/R200 80611105805/
Find the version of Commons logging that it is looking for, and place in
your eclipse/plugins directory.
I've created the following bug to track this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=243058
Dave
Re: Unable to install XSL tooling 0.5.0.v200806220600 from update site [message #218918 is a reply to message #218846] |
Tue, 05 August 2008 08:46 |
>> Hi Dave,
>> I put the apache.commons.logging
>> < http://download.eclipse.org/tools/orbit/downloads/drops/R200 80611105805/bundles/org.apache.commons.logging_1.0.4.v200806 05-1930.jar>
>> jar into my dropins folder, and it turns up in the "About Eclipse
>> SDK"-plugins-list with the exact version as seems to be required.
>> Unfortunately, I still get the same error. It may be P2 being
>> confused here.
> Yeah, I think it might be. What you could try restarting with a
> -clean and see if that reset P2. If not....then you can do an
> Uninstall of XSL Tools, and then try adding it back in again.
I tried it all, without success. There is a another
org.apache.commons.logging 1.1.1v200803061910 installed, but
unfortunately I don't know what feature it comes from, and I don't know
how to find out.
> On a side note, we should be having a 0.5M9 build available sometime
> next week for XSL Tools.
> Dave
Re: Unable to install XSL tooling 0.5.0.v200806220600 from update site [message #218924 is a reply to message #218846] |
Tue, 05 August 2008 08:56 |
In fact I'm not able to uninstall "XSL Feature (Incubating"
0.5.0.v20080504! I tried it multiple times in "Software Updates..."
using the "Uninstall..." button, properly being asked to confirm
uninstalling. However, when I press "Finish", nothing happens, and the
feature is still present in my configuration, also after a restart.
There are all kinds of "Problems resolving provisioning plan" in my
Error Log, so I guess my config is severly broken now. Oh dear. I had
always hoped that when only using P2 to modify the configuration, it
would stay consistent.
>> Hi Dave,
>> confused here.
> Dave
Re: Unable to install XSL tooling 0.5.0.v200806220600 from update site [message #218940 is a reply to message #218924] |
Tue, 05 August 2008 13:35 |
Jorg,
It sounds like you might be bit by a couple of bugs:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241637
https://bugs.eclipse.org/bugs/show_bug.cgi?id=217846
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198742
If your problem doesn't match any of those, then I would report a bug.
Now to get you working here is what I suggest. Do the brute force method.
Locate all the org.eclipse.wst.xsl.* plugins in the plugins folder, and
delete them. Find the org.eclipse.wst.xsl.feature component in the
features folder and delete it.
Restart eclipse with the -clean option.
Add back the WTP update site, and re-install the XSL Tools plugins, this
should get you going again.
But again, I would open a bug against the eclipse platform, Equinox / P2
and put the steps to reproduce this there along with any error log
information you have.
Dave
>>> Hi Dave,
>>> confused here.
>> Dave
Re: Unable to install XSL tooling 0.5.0.v200806220600 from update site [message #219105 is a reply to message #218940] |
Fri, 08 August 2008 15:53 |
--------------060209060208050507020106
OK what I did was reinstall Ganymede completely, including WTP from
Ganymede. Now when I try to install the XSL feature from the WTP update
site (http://download.eclipse.org/webtools/updates/) , I get:
An error occurred while collecting items to be installed
No repository found containing:
java_cup.runtime/osgi.bundle/0.10.0.v200803061811
org.apache.bcel/osgi.bundle/5.2.0.v200803061811
org.apache.commons.jxpath/osgi.bundle/1.2.0.v20080604-1500
org.apache.commons.logging/osgi.bundle/1.1.1.v20080605-1935
org.apache.xalan/osgi.bundle/2.7.1.v200806030242
org.eclipse.wst.xml.ui.editor.outline/osgi.bundle/0.5.0.v200 80323
org.eclipse.wst.xml.xpath.core/osgi.bundle/0.5.0.v20080526
org.eclipse.wst.xml.xpath.ui/osgi.bundle/0.5.0.v20080512
org.eclipse.wst.xsl.core/osgi.bundle/0.5.0.v20080528
org.eclipse.wst.xsl.debug/osgi.bundle/0.5.0.v20080523
org.eclipse.wst.xsl.debug.ui/osgi.bundle/0.5.0.v20080615
org.eclipse.wst.xsl.doc/osgi.bundle/0.5.0.v20080504
org.eclipse.wst.xsl.feature/org.eclipse.update.feature/0.5.0 .v200806220600-79871EC3wSUITbgY9SSF8
org.eclipse.wst.xsl.launching/osgi.bundle/0.5.0.v20080508
org.eclipse.wst.xsl.ui/osgi.bundle/0.5.0.v20080615
org.eclipse.wst.xsl.xalan/osgi.bundle/0.5.0.v20080523
Now, for a change, that's *after* P2 let me proceed with the install,
i.e. it did not detect any unresolved dependencies. I believe P2 has
still some way to go before becoming predictable and reliable...
David Carver wrote:
> Jorg,
> method.
> and delete them. Find the org.eclipse.wst.xsl.feature component in
> the features folder and delete it.
> this should get you going again.
> P2 and put the steps to reproduce this there along with any error log
> Dave
> J
Re: Unable to install XSL tooling 0.5.0.v200806220600 from update site [message #219113 is a reply to message #219105] |
Fri, 08 August 2008 18:54 |
Yeah, it still has some issues, hopefully with the 3.4.1 maintenance
it'll be fixed up a bit more.
In the mean time, you can always, grab a copy of the ZIP file from the
Web Tools Download site, and install it manually. Don't use the drop
ins folder as it may not pick it up from there (known issues with dropin
in P2 still).
Dave
> David Carver wrote:
>> Jorg,
>> method.
>> Dave
>>> the feature is still present in my configuration, also after a restart.
>>>>> Hi Dave,
>>>>> confused here.
>>>> Dave
Current Time: Thu Apr 18 10:37:54 GMT 2024
Powered by FUDForum. Page generated in 0.02819 seconds
