Home » Language IDEs » ServerTools (WTP) » JSDT won't fully recognize referenced library
JSDT won't fully recognize referenced library [message #217207] Wed, 09 July 2008 14:30 Go to next message
Peter Darrow is currently offline Peter DarrowFriend
I'm having trouble getting JSDT to fully recognize the YUI Javascript
library. When I create a project and add YUI as a library reference, only
certain components are recognized by the interpreter. Please see
screenshot here: http://i33.tinypic.com/2hf278m.png
As you can see, on the left there are some classes that are recognized
from the YUI library (and in the editor: line 18, YAHOO.widget.DataTable),
but many are not (hence all of the warnings.) Is there something
fundamental that I'm missing, or are large Javascript libraries not
supported?
Peter
Re: JSDT won't fully recognize referenced library [message #217328 is a reply to message #217207] Thu, 10 July 2008 18:59 Go to previous messageGo to next message
Bradley Childs is currently offline Bradley ChildsFriend
There is no javascript debugging support. Check out the ATF project for
javascript firefox debugging....
-brad
"Peter D" <peter@jasco.com> wrote in message
news:4c303dae133ace0a8f812572a29ff2ac$1@www.eclipse.org...
> supported?
> Peter
Re: JSDT won't fully recognize referenced library [message #217439 is a reply to message #217328] Fri, 11 July 2008 17:20 Go to previous messageGo to next message
I don't think my original post said anything about debugging. I'm talking
strictly about code completion and real-time syntax error checking.
Peter
Re: JSDT won't fully recognize referenced library [message #217543 is a reply to message #217439] Fri, 11 July 2008 17:56 Go to previous messageGo to next message
Originally posted by: hyysguyang.gmail.com
Peter D 写道:
> talking strictly about code completion and real-time syntax error checking.
> Peter
Yes ,I got the same error when use the jQuery,In fact can't code
completion and tell me the $ is undefined.
Re: JSDT won't fully recognize referenced library [message #217603 is a reply to message #217439] Mon, 14 July 2008 20:48 Go to previous message
Sorry, i posted to the wrong thread there--
In response to:
>certain components are recognized by the interpreter. Please see screenshot
JSDT works well with common usage JavaScript, but must rely on inferencing
extensions to fully build class structure in the bigger toolkits. This is
because of quirky backdoor mechanisms most of these toolkits use to define
classes and types. The quirks are valid JavaScript, but the types/classes
aren't visible until execution and don't follow a standard, or atleast
common definition structure.
In the YUI case, most of the JavaScript definition is pretty common, but
some of it's also defined during runtime or through chains of anonymous
structures. Due to the runtime definitions, and other funk there will be
incomplete class/type definitions.
I encourage you to document specific problems. That way we can begin
writing inferencing engines that recognize the proprietary structures in YUI
toolkits.
-brad
news:a279ea34e2c24a2f661ec88bbc96e637$1@www.eclipse.org...
> Peter
Previous Topic:Remote Deployment in eclipse
Next Topic:OS specific property defaults in Server Def?
Current Time: Sat May 15 12:14:51 GMT 2021
Powered by FUDForum. Page generated in 0.01824 seconds
