Home » Modeling » TMF (Xtext) » generate property from referenced object
generate property from referenced object [message #1293652] Sat, 12 April 2014 21:08 Go to next message
Chris Klein is currently offline Chris KleinFriend
my first adventures in xtext were very positive. The plugin was working in an instant and its a pleasure to use ones own language using an inteligent editor.
But now i got stuck using referenced rules. Taking the 15 minutes example i would like to do something like:
Entity :
  'entity' name = ID
Entity2 :
  'entity2' name = [Entity]
The rule Entity2 doesnt work as expected. I think its because [Entity] returns the referenced object but not a string.
The Objects of entity2 should have the same name as the referenced Entity object. In other languages i'd use a statement like
Entity2 :
  'entity2' name = [Entity].name
But, of course, this doesnt work too.
I hope i have made my point clear. Does XText allow to do something like this in grammar only? Or do I have to change some java internals of the editor?
Thanks in advance for your help,
chris
Re: generate property from referenced object [message #1294839 is a reply to message #1293652] Sun, 13 April 2014 21:17 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi you have to adapt the iqualifiednameprovider (subxlassing
DefaultDeclarativeQualifiedNameProvider) and use NodeModelUtil
(findNodesForFeature) to extract the cross referenced name string
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Re: generate property from referenced object [message #1296048 is a reply to message #1294839] Mon, 14 April 2014 19:41 Go to previous messageGo to next message
Hi christian,
thanks for the pointers. Using your keywords i found your blog post under
christiandietrich.wordpress.com/2011/07/16/iqualifiednameproviders-in-xtext-2-0/
that shows how to use the DefaultDeclarativeQualifiedNameProvider
I implemented qualifiedName as follows
     QualifiedName qualifiedName(Entity2 e) {
    	 List<INode> nl=NodeModelUtils.findNodesForFeature(e,
	e.eClass().getEStructuralFeature(skoL.dsl.impl.DslPackageImpl.ENTITY2__REF));
    	INode node=nl.get(0);
    	 String vName=node.getText();
    	 EObject temp = e;
		while (temp.eContainer() != null) {
			temp = temp.eContainer();
			QualifiedName parentsQualifiedName = getFullyQualifiedName(temp);
			if (parentsQualifiedName != null)
				return parentsQualifiedName.append(vName);
        return QualifiedName.create(vName);
this makes Entity2 visible in the global object list (under ctrl+shift+f3).
But I still have one problem: Entity2 Objects dont show up in auto-completion.(ctrl+space) I suspect this is due to entity2 objects having no attribute called "name". How can I make the objects appear in auto-complete?
Re: generate property from referenced object [message #1296064 is a reply to message #1296048] Mon, 14 April 2014 19:56 Go to previous messageGo to next message
Please share a complete reproducible example. I can't follow your
problem
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: generate property from referenced object [message #1296747 is a reply to message #1296064] Tue, 15 April 2014 07:01 Go to previous messageGo to next message
P:S: if they are in the global index the shall occury locally too (if your grammar is correct)
Re: generate property from referenced object [message #1307704 is a reply to message #1296747] Mon, 21 April 2014 18:42 Go to previous messageGo to next message
i solved the problem:
following instructions on
malubu.wordpress.com/2012/05/07/post-processing-vs-post-initialization/
i added a "name" property to my Entity2 object and now it shows up in auto-completion
Re: generate property from referenced object [message #1307743 is a reply to message #1307704] Mon, 21 April 2014 19:10 Go to previous message
hi++QualifiedName qualifiedName(Entity2 e) {
should already have done that
Previous Topic:Disabling auto-insertion of quotes
Next Topic:Rule written for DSL in xtext, It is not working as expected
Current Time: Sat Feb 22 17:08:12 GMT 2020
Powered by FUDForum. Page generated in 0.07386 seconds
