Home » Modeling » GMF (Graphical Modeling Framework) » How to call own layoutProvider from "Arrange All"
How to call own layoutProvider from "Arrange All" [message #216611] Wed, 28 January 2009 18:13 Go to next message
Martin Jacob is currently offline Martin JacobFriend
Hi everyone,
I was searching on the mailing list but did not find a sufficient answer fop my problem.
I want to use my own layoutProvider while using the already existing menu item "Arrange All".
I did the following things so far:
1. Add the extension point, see below:
<extension name="PSC Viewer Layout Provider" point="org.eclipse.gmf.runtime.diagram.ui.layoutProviders">
<layoutProvider class="ui.diagram.providers.LayoutProvider">
<Priority name="Highest">
</Priority>
</layoutProvider>
</extension>
2. Create a class derived from org.eclipse.gmf.runtime.diagram.ui.services.layout.AbstractL ayoutNodeProvider
public class PscViewerLayoutProvider extends AbstractLayoutNodeProvider {
public Runnable layoutLayoutNodes(List layoutNodes,
boolean offsetFromBoundingBox, IAdaptable layoutHint) {
System.out.println("layoutNodes: "+layoutNodes.toString());
System.out.println("offsetFromBoundingBox: "+offsetFromBoundingBox);
System.out.println("layoutHint: "+layoutHint.toString());
return null;
public boolean provides(IOperation operation) {
System.out.println(""+operation.toString());
if (operation instanceof org.eclipse.gmf.runtime.diagram.ui.services.layout.ILayoutNo deOperation) {
System.out.println("true");
return true;
System.out.println("false");
return false;
I would expect to see at least the println while calling "Arrange All". But I don't see any thing at System.out!
Does any one could please give me a hint how to solve the problem?
Thanks, Martin
Re: How to call own layoutProvider from "Arrange All" [message #216637 is a reply to message #216611] Thu, 29 January 2009 08:49 Go to previous messageGo to next message
Mariot Chauvin is currently offline Mariot ChauvinFriend
Hi Martin,
It seems to me that your class value in plugin.xml is not the right one :
should be :
<layoutProvider class="yourcompany.yourpackage.PscViewerLayoutProvider">
BTW debugging with system.out is evil :P, why you do not simply add breakpoints ?
Mariot
Martin Jacob a écrit :
> Hi everyone,
> </Priority>
> </layoutProvider>
> </extension>
> return null;
> return true;
> return false;
> Thanks, Martin
Re: How to call own layoutProvider from "Arrange All" [message #216644 is a reply to message #216637] Thu, 29 January 2009 09:15 Go to previous messageGo to next message
Hi Mariot,
the package and class name in plugin.xml is correct. (I just delete some parts for posting it here)
And yes u are right system.out is evil, its just a old habit from C programming....
Now I used the debugger but got the same result. My layout provider will not be called :(
Any other suggestions?
Cheers, Martin
Mariot Chauvin wrote, On 29.01.2009 09:49:
> Hi Martin,
> should be :
> Regards,
> Mariot
>> Hi everyone,
>> </Priority>
>> </layoutProvider>
>> </extension>
>> return null;
>> return true;
>> return false;
>> Thanks, Martin
Re: How to call own layoutProvider from "Arrange All" [message #216652 is a reply to message #216644] Thu, 29 January 2009 09:46 Go to previous messageGo to next message
Martin,
Is there another layout defined with the highest priority ?
If you externalize your layout in a plug-in check that you plug-in started without errors ("Show View" -> "Other" -> "Plug-in Registry").
If you install GMF sdk there is also an example of layout provider ("New" -> "Example/ GMF PLugins/Square layout provider") to compare.
Mariot
> Hi Mariot,
> programming....
> not be called :(
> Cheers, Martin
>> Hi Martin,
>> should be :
>> breakpoints ?
>> Regards,
>> Mariot
>>> Hi everyone,
>>> </Priority>
>>> </layoutProvider>
>>> </extension>
>>> return null;
>>> return true;
>>> return false;
>>> Thanks, Martin
Re: How to call own layoutProvider from "Arrange All" [message #216658 is a reply to message #216652] Thu, 29 January 2009 10:08 Go to previous message
Hi Mariot,
thanks for the hint!
In fact the plugin could not be loaded because a ClassNotFoundException was thrown...
Now I copied the package name and class name to the extension point in plugin.xml. And it works! There must be a typo some where...
Regards, Martin
Mariot Chauvin wrote, On 29.01.2009 10:46:
> Martin,
> Regards,
> Mariot
>> Hi Mariot,
>> programming....
>> not be called :(
>> Cheers, Martin
>>> Hi Martin,
>>> should be :
>>> breakpoints ?
>>> Regards,
>>> Mariot
>>>> Hi everyone,
>>>> </Priority>
>>>> </layoutProvider>
>>>> </extension>
>>>> return null;
>>>> return true;
>>>> return false;
>>>> Thanks, Martin
Previous Topic:[Announce] GMF 2.2.0 I200901281927 is available
Next Topic:Hide 'Input methods' in Context Menu
Current Time: Mon Apr 12 02:16:22 GMT 2021
Powered by FUDForum. Page generated in 0.01741 seconds
