Home » Eclipse Projects » GEF3D » rotation of planes
rotation of planes [message #1760] Tue, 27 January 2009 11:07 Go to next message
Matthias Then is currently offline Matthias ThenFriend
I started to change the visualization in my tool from 2D to 3D. Until now
I worked with GEF and now I'm using GEF3D. My impression: It works much
better and is much easier to use than I thought. :-)
What I did not find out yet: When I create planes I can only position them
one over another. Does GEF3D support rotation of planes? If it does, how
does that work?
Matthias Then
Re: rotation of planes [message #1767 is a reply to message #1760] Tue, 03 February 2009 10:37 Go to previous messageGo to next message
Jens von Pilgrim is currently offline Jens von PilgrimFriend
On 2009-01-27 12:07:16 +0100, matthias.then@fernuni-hagen.de (Matthias
We're working hard on making it easy for GEF-editor developers ;-)
> them one over another. Does GEF3D support rotation of planes? If it
> does, how does that work?
GEF3D supports rotation of planes. As a matter of fact, GEF3D is a
"real" 3D tool, that is 3D figures can be positioned (and rotated)
anywhere. All our examples are using special layouts, so you may get
the impression that GEF3D is limited to stack layout or something like
this, but this is not true.
In the multi-editor example, we do not use a layout manager (this is a
hack, we have to change this in future versions ;-) ).
Just have a look at
org.eclipse.gef3d.ext/src/java/org/eclipse/gef3d/ext/multied itor/MultiEditorModelContainerFigure.java
The
layout manager used is a LayoutXYZ-layout manager, that is this manager
delegates the calculation of figures to the children. In other words:
This is a layout manager which uses the locations (and rotation
settings) of the children figures (this layout manager is used very
often, but from a technical perspective, it's an exception since it
delegates the calculation to the figures). When a new child figure is
added, we calculate its new position on the fly:
if (!(fig3D instanceof IInterModelDiagram)) {
Vector3fImpl vec = new Vector3fImpl(fig3D.getLocation3D());
vec.z += dz;
fig3D.setLocation3D(vec);
dz += 1000;
Again: this is a hack, but it works. You can simply write your own
container figure and change its behaviour. Maybe you can even write a
new LayoutManager and contribute it ;-)
You can rotate the planes, this is working. There is a known bug (I
haven't submitted a bug report, mea maxima culpa!): the
intermodel-connections, i.e. connections between elements on different
planes, are not located accordingly. I was about to submit a bug, but I
wanted to have a demo example for that first.
Jens
Re: rotation of planes [message #1772 is a reply to message #1767] Tue, 03 February 2009 10:52 Go to previous messageGo to next message
On 2009-02-03 11:37:20 +0100, Jens v.P. <developer@jevopi.de> said:
> I haven't submitted a bug report, mea maxima culpa!
Created a bug report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=263441
I have attached an image to the bug report on which you can see the
rotated planes. I also added a code snippet rotating the planes (around
the z-axis).
Jens
Re: rotation of planes [message #1777 is a reply to message #1772] Thu, 05 February 2009 12:15 Go to previous messageGo to next message
Hi Jens,
thank you very much for your help!
I modified my code as you described and it works.
The only problem left is the intermodel-connection-bug you described in
your bug report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=263441. :-)
Matthias
Re: rotation of planes [message #1783 is a reply to message #1772] Thu, 05 February 2009 12:22 Go to previous message
Hi Jens,
Matthias
> the z-axis).
> Cheers,
> Jens
Re: rotation of planes [message #560950 is a reply to message #1760] Tue, 03 February 2009 10:37 Go to previous message
Just have a look at
The
vec.z += dz;
dz += 1000;
Jens
Re: rotation of planes [message #560962 is a reply to message #1767] Tue, 03 February 2009 10:52 Go to previous message
the z-axis).
Jens
Re: rotation of planes [message #560975 is a reply to message #1772] Thu, 05 February 2009 12:15 Go to previous message
Hi Jens,
your bug report: https://bugs.eclipse.org/bugs/show_bug.cgi?id=263441 :-)
Matthias
Re: rotation of planes [message #560987 is a reply to message #1772] Thu, 05 February 2009 12:22 Go to previous message
Hi Jens,
Matthias
> the z-axis).
> Cheers,
> Jens
Previous Topic:rotation of planes
Next Topic:really interesting
Current Time: Sat Jan 16 04:01:21 GMT 2021
Powered by FUDForum. Page generated in 0.01615 seconds
