Home » Modeling » Compare » Compatibility of version 3?
Compatibility of version 3? [message #1284364] Fri, 04 April 2014 11:39 Go to next message
Anja Hansen is currently offline Anja HansenFriend
I'm preparing the implementation of EMF Compare in the eclipse version that we distribute to users and developers.
So far I've been looking at EMF Compare 2.1, but I can see that v 3.0 is just around the corner (based on all your documentation updates).
What EMF version will EMF Compare 3.0 use?
Is it possible for you to add version 3.0 to the "Compatibility" view of
http://www.eclipse.org/emf/compare/documentation/latest/user/user-guide.html#Installing_EMF_Compare ?
We are currently using eclipse 3.8.
Re: Compatibility of version 3? [message #1286915 is a reply to message #1284364] Mon, 07 April 2014 07:31 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Hi Anja,
The core and UI of EMF Compare 3.0 are compatible from Helios (3.6) to Luna (4.4), and is untested on Galileo (3.5).
Do note that parts of EMF Compare are not compatible with this whole range, most notably the UML support (which requires UML 5.0, only present in Luna) and the diagram comparison support.
Laurent Goubet
Obeo
Previous Topic:[Bug?] NPE during comparison of EObjects
Next Topic:[EMFCompare] duplicate post. Please ignore
Current Time: Thu Mar 04 10:35:19 GMT 2021
Powered by FUDForum. Page generated in 0.01885 seconds
