How to avoid useless queries to be executed [message #1283594] |
Thu, 03 April 2014 15:48 |
ing omini Messages: 26 Registered: March 2012 |
Junior Member |
Hi BIRT developers!
I've designed a parametric report in which each section can be shown or not depending on parameters configuration.
Example:
loop over states...
chart "population by city" --> only to be shown if param_city = true
chart "population by gender" --> only to be shown if param_gender = true
I'm using "visibility" properties to hide report section when not necessary, example when the corresponding parameter is false.
Anyway, my problem is that visibility only affects the rendering output, while the underlying dataset query is executed in any case, thus increasing the load on database and the report generation time.
As a workaround, I tried to optimize the queries by putting conditions like
select ...
from ...
where ...
and ? = 'true'
where the ? is replaced by the parameter which enables the section.
This is reducing the query time a lot, but not removing the query execution overhead completely (so the query is parsed, parameters are replaced, the execution is made, the fetch retrieves no rows, and so on...)
For reports looping over a lot of items, this useless overhead time cannot be ignored.
So my question is... is there any way of "skipping" a report element (rather than hiding it)?
Thanks in advance!
FUDForum. Page generated in 0.03334 seconds
