Home » Modeling » M2T (model-to-text transformation) » Acceleo - Differences between generations runner(Acceleo - Differences between generations runner)
Acceleo - Differences between generations runner [message #1283249] Thu, 03 April 2014 07:48 Go to next message
Federico Nicoli is currently offline Federico NicoliFriend
i have a problem with the generations of Acceleo. The problem is this, when I run the transformation with the runner Acceleo I get a different result than the generation made ​​with the runner java.
I need to configure something in the class that manages the run? Such as the registration of service java?
For example :
AcceleoServicesRegistry.INSTANCE.addServiceClass("MyId", "class");
thank you very much.
Re: Acceleo - Differences between generations runner [message #1283375 is a reply to message #1283249] Thu, 03 April 2014 10:51 Go to previous messageGo to next message
When you have a version that works, debugging is much easier.
See what the version that works does and do the same in the other version.
Ed Willink
On 03/04/2014 08:48, Federico Nicoli wrote:
> different result than the generation made ​​with the runner java. I
> For example :
Re: Acceleo - Differences between generations runner [message #1283438 is a reply to message #1283375] Thu, 03 April 2014 12:24 Go to previous message
ok but generations with both runners should not produce the same output?
Previous Topic:[Acceleo] No output despite correct input
Next Topic:Access metamodel elemnets from model
Current Time: Tue Sep 27 22:09:12 GMT 2022
Powered by FUDForum. Page generated in 0.02213 seconds
