Home » Eclipse Projects » Eclipse 4 » TrimBar maximum height
TrimBar maximum height [message #1282440] Wed, 02 April 2014 10:00 Go to next message
Bastian Wagenfeld is currently offline Bastian WagenfeldFriend
I added a ToolControl to my ToolBar (in a TrimBar at the top side), but the ToolControl's lower side is a little "trimmed". What is the maximum height of a ToolBar and is it possible to get it larger?
Or as some kind of workaround: Is it possible to place two ToolBars among each other? I didn't get this to work, either.
Best regards
Bastian
Re: TrimBar maximum height [message #1282713 is a reply to message #1282440] Wed, 02 April 2014 17:55 Go to previous message
Eric Moffatt is currently offline Eric MoffattFriend
If you don't have any other 'real' toolbar buttons then I'd suggest that you directly add the MToolControl to the TrimBar rather than adding toolbar with a control in it. There are known issues on more than one platform regarding toolbars containing only controls. Also in many cases the height of the toolbar is determined by its first *button*.
Previous Topic:How can I get ISharedImages?
Next Topic:Remove Import menu item
Current Time: Fri Jul 30 21:23:01 GMT 2021
Powered by FUDForum. Page generated in 0.02007 seconds
