Working with CSS Framework [message #213503] |
Fri, 09 May 2008 15:48  |
Originally posted by: chlache.talita.org
I am trying to figure out how to use the CSS implementation from core.css.
I assume that CSSStyleSheetImpl(ICSSStyleSheet) is the Base to start from.
Is that correct?
My questions are:
How do i create a ICSSStyleSheet from a URl(/path/stylesheet.css)?
How do create an empty (new) ICSSStyleSheet (is the correct way to call new DOMCSSImpl.createCSSStyleSheet()?)
How do i correctly add a rule to ICSSStyleSheet (call CSSStyleSheetImpl insertRule(String rule, int index))?
How do I save an ICSSStyleSheet to file?
Thanks in advance
Andreas Chlache
Re: Working with CSS Framework [message #225601 is a reply to message #213503] |
Tue, 23 December 2008 12:28  |
> Is that correct?
> My questions are:
> Thanks in advance
> Andreas Chlache
org.eclipse.wst.css.core.tests
Simple answer.
Download from cvs.
FUDForum. Page generated in 0.03733 seconds
