Home » Eclipse Projects » Eclipse 4 » Add button to Console toolbar(How to add a button to the Console toolbar.)
Add button to Console toolbar [message #1279202] Fri, 28 March 2014 11:37 Go to next message
Peter Robertson is currently offline Peter RobertsonFriend
I wish to add a button to an application's Console toolbar.
Putting the following in the relevant plugin.xml successfully puts a working button on the Console toolbar:
<extension point="org.eclipse.ui.viewActions">
   <viewContribution
      id="com.xxx.yyy.launch.viewContribution1"
      targetID="org.eclipse.ui.console.ConsoleView">
      <action label="Expand"
              class="com.xxx.yyy.launch.actions.ExpandAction"
              icon="icons/expand.gif"
              id="com.xxx.yyy.launch.action.expand"
              style="push"
              toolbarPath="toolbar"
              tooltip="Expand"/>
   </viewContribution>
</extension>
However, the extension point, viewContribution, and action are marked as deprecated.
I have tried to get the same effect using the extension point org.eclipse.ui.commands (as indicated in the deprecated message) like this,
where expand.button has been defined as a command:
<extension point="org.eclipse.ui.menus">
   <menuContribution locationURI="toolbar:org.eclipse.ui.main.toolbar">
      <toolbar id="toolbar1">
         <command commandId="expand.button"/>
      </toolbar>
   </menuContribution>
   <menuContribution locationURI="toolbar:org.eclipse.ui.console.ConsoleView">
      <toolbar id="toolbar2">
      </toolbar>
   </menuContribution>
</extension>
This correctly puts a working 'expand' button on the main toolbar, but one does not appear on the Console toolbar.
Can anyone suggest what is wrong with this?
Re: Add button to Console toolbar [message #1313376 is a reply to message #1279202] Thu, 24 April 2014 21:27 Go to previous message
Wim Jongman is currently offline Wim JongmanFriend
Hi Peter,
You cannot put a toolbar in the toolbar of a view. Put a command directly on the view toolbar like so:
</menuContribution>
Wim
Previous Topic:Eclipse 4 contributions to the IDE
Next Topic:Persist selection on tree viewer on restart of application using memento
Current Time: Sat Jul 24 01:28:40 GMT 2021
Powered by FUDForum. Page generated in 0.02151 seconds
